Sponsored by: Real Truck
Check Engine Lite
Old Apr 4, 2006 | 06:19 AM
02f350Longy's Avatar
02f350Longy
Check Engine Lite
hey guys...
i have an 02 f350 5.4...i put a k and n drop in filter and a magnaflow muffler on over the last weekend. drove the truck on sunday all day hauling wood and then coming to work monday the check lite came on. any ideas??? i went to auto zone yesterday and the guy said there were no codes stored, but the lite it on? any help would be appreciated, the lite is bugging the #@$% out of me...
Old Apr 4, 2006 | 06:33 AM
Big Orn's Avatar
Big Orn
Got to go somewhere to read the codes - could be anything. Might or might not be coincidence with the K&N and exhaust.
Maybe the guy didn't know how to pull the codes...?
Old Apr 4, 2006 | 06:35 AM
02f350Longy
i also wanted to say that i have tried to clean the MAF with brake cleaner like someone else said in a thread....thanks
FortyFords's Avatar
FortyFords
Had you disconnected the battery when doing your upgrades?
problably a p1000 code which the guy at autozone new it wasn't a problem code.
Or the guy didn't know how to use the scanner.
which happens alot.
Disconnect the battery again and see if the light comes back ,then get it scanned again.
get the codes and we can help
I have a list of possible problems but without codes you'd be chasin your tail.
Rich
on edit:
Sorry Mr Big ,didn't know you were on the case here,we were typing at the same time
Old Apr 4, 2006 | 06:40 AM
02f350Longy
thanks guys...
i unhooked the battery last nite...still came on this morning. im going to a buddy's shop to have him check it. ill get back to you later or tomorrow about the code/problems. i just though someone else may have had a similar problem after exhaust and kn...thanks
Old Apr 4, 2006 | 06:45 AM
Big Orn's Avatar
Big Orn
We could guess...
Get them codes...nobody wants to chase tails...
Old Apr 4, 2006 | 06:47 AM
FortyFords's Avatar
FortyFords
Chk all your connections at the maf
and any vacum hoses you may have knocked loose in the engine compartment.
Save yourself before your buddy rips you (makes jokes on you) not the money rip.
Rich Hey Mr Big wake up
Old Apr 4, 2006 | 07:37 AM
Big Orn's Avatar
Big Orn
Originally Posted by FortyFords
Hey Mr Big wake up
What time is it? I hate this Daylight Saving Time BS... This extra hour of sunlight is apt to burn up my garden...
Old Apr 4, 2006 | 02:10 PM
02f350Longy
i got codes p1000, and p1633 - which says something about voltage too low? any suggestions?
Old Apr 4, 2006 | 02:55 PM
biz4two's Avatar
biz4two
P1633 Keep Alive Power Voltage Too Low : This I am uncertain. Could it be the alternator/regulator output??? Sorry, but no help here.
P1000 OBD-II Monitor Testing Incomplete : This can be reset with no issues. Once reset...then drive for 40 - 60 miles for the PCM to complete its testing mode. That is done each time the battery has been disconnected. You should not be concerned.
biz
_______________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Old Apr 4, 2006 | 03:32 PM
Big Orn's Avatar
Big Orn
Have you installed a chip or tuner?
Have you checked all the fuses? This is a sign that maybe the PCM is going bad if you've not tampered with it in some way. Even if you unhook the battery this one may come right back. May want to let a shop diagnose it on a tester.
Old Apr 5, 2006 | 06:11 AM
02f350Longy
it was a fuse...#36. i hope that is all it was...i fixed it yesterday and the lite has not come on since...
Old Apr 5, 2006 | 01:43 PM
FortyFords's Avatar
FortyFords
fuse 36 was blown?????
Hmmm interesting!
any water on the driverside under the floor mat?
Possible windshield leak.
That be very interesting
Rich
Old Apr 6, 2006 | 06:53 AM
02f350Longy
nope nothing like that...i would like to know what caused it or what can cuase that circuit to blow...if any one has suggestions...please let me know
woodster69
New Member Introductions
Aug 29, 2014 11:11 PM
richieschlitt
Feb 1, 2014 06:26 PM
docholy45
Nov 28, 2012 05:28 PM
MintHill68f100
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jul 29, 2005 04:21 PM
Ed the outdoorman
Aug 5, 2004 01:40 PM
