Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
scouring powder
Old Apr 22, 2002 | 08:17 PM
51frrdtrk's Avatar
51frrdtrk
scouring powder
Old May 3, 2002 | 11:16 AM
airharley's Avatar
airharley
scouring powder
Do you guys use scouring powder to help remove stripped, rusted, and over torqued screws? It's a god sent around here with some of the knuckle heads who over tighten or strip out panel screws on A/C. Works on bolt heads too.
Old May 3, 2002 | 02:22 PM
Raul's Avatar
Raul
scouring powder
Call me slow. How do you use scouring powder for these purposes?
Old May 3, 2002 | 03:52 PM
aerocolorado's Avatar
aerocolorado
scouring powder
I'm slower yet. I can't see how Ajax can remove a screw. Rust, yes, but impacted bolts, no. Share the secret with your denser brethern.
Old May 4, 2002 | 08:40 PM
Tedster9's Avatar
Tedster9
scouring powder
Neat trick, learned that in the Army working on aircraft from an old sheet metal guy.
Works real good to *prevent* stripped phillips head screws that are torqued way beyond spec.
Okay. Say you have a number 2 phillips screw that is just reefed in there tighter than a mini skirt on prom night.
When the wife isn't looking, ****** the Comet from under the sink, take to garage. Deposit a good dollop of spit (it's handy) on the tip of your bit or screwdriver and dunk same into Comet so it has a good coating over the bit. For whatever reason, the comet fills the gap(s) between the screw and bit and makes a very tight fit without slipping, usually giving enough gription to remove the screw before stripping. Works great.
Old May 5, 2002 | 01:10 PM
TheWiz427's Avatar
TheWiz427
scouring powder
Interesting i'll have to try that
Old May 5, 2002 | 04:00 PM
DailyDriver's Avatar
DailyDriver
scouring powder
Yeah, me too. Thanks!
Old May 6, 2002 | 04:38 PM
aerocolorado
scouring powder
Thanks for the clarification. Although necessity is the mother of invention, don't you often wonder what would prompt someone to even think about using scouring powder this way?
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
