Power Brakes (different from below)
Old Apr 2, 2006 | 08:05 PM
Young_unn's Avatar
Young_unn
<hr style="color: rgb(102, 102, 102);" size="1"> i pulled off the complete brake system off my 73 econoline. i have the booster the mounts and the master cylinder, it is the same split master cylinder as i have in my truck.
i should be fine mounting it to my truck and using it. is there any way i can get the needed vacuum off of my 223.
i may put the 302 C-4 from the van into the truck at a later date
Old Apr 3, 2006 | 04:19 AM
jowilker's Avatar
jowilker
Sounds like you have a great chance to have a real mess on your hands, with mixing of parts. IMHO
John
Old Apr 3, 2006 | 08:40 AM
FordBoypete's Avatar
FordBoypete
If you've a 223 I-6 engine in your truck, nothing in your OEM Brake system is close to being remotely the "same" as the brakes in a 1973 E Series Van. It's a split system.
I agree with Jowilker 100%. . . . . You will be Creating Problems for yourself
FBp
Old Apr 3, 2006 | 04:28 PM
Young_unn's Avatar
Young_unn
even tho i have a split system in my truck?
Old Apr 3, 2006 | 05:25 PM
FordBoypete
What is your truck?
Old Apr 3, 2006 | 06:10 PM
Young_unn's Avatar
Young_unn
63 f-100,
i dont think i have the original brake cylder, it is a split system, im also 99% sure
ill try and get pictures
Old Apr 5, 2006 | 07:40 AM
Young_unn's Avatar
Young_unn
U can see the master i have in my truck in my gallery, its a little dark and in the back, but its there. i'll take a good picture tonight or tomarrow
Old Apr 5, 2006 | 08:54 AM
garbz2's Avatar
garbz2
Ok, narrowing down some... By split system do you mean 2 master cylenders?
or
A single master cylender with 2 outlets ports?
Garbz
Old Apr 5, 2006 | 12:43 PM
FordBoypete
A split system to me has 2 independent outlets going to a Proportioning Valve which splits the two lines into three lines, two front wheel brake lines plus a single rear brake line going back to the "Tee" on rear axle hosuing, that services both wheels from the single rear line.
It ends up as 3 application circuits, they would be a L/F, a R/F & Rear circuit. It has to be Balanced after it's bled when a pressure bleeder is not used to bleed it.
FBp
Old Apr 5, 2006 | 07:11 PM
Young_unn's Avatar
Young_unn
thats what i have
almost 100% sure,
im going to run over and get pictures now, ill update my gallery in an hour for you guys
Old Apr 5, 2006 | 08:31 PM
Sam_Fear's Avatar
Sam_Fear
That appears to be a dual M/C in the shadows.
Old Apr 5, 2006 | 08:51 PM
Young_unn's Avatar
Young_unn
its definantly a dual. i have pictures which i will put in a gallery at 1130 ish
Old Apr 10, 2006 | 08:55 PM
Young_unn's Avatar
Young_unn
I Have Pictures Look And Tell Me What U See!
Old Apr 11, 2006 | 05:32 PM
Young_unn's Avatar
Young_unn
so tell me what i have and if it will covert, it seems to match to me
