erratic ignition
Old Apr 2, 2006 | 06:24 PM
heathkiks's Avatar
heathkiks
erratic ignition
I recently put a '74 460 into a '79 f-150, 4 speed, 4x4.
The problem is; erratic ignition. The engine ran perfectly out of the doner pickup. There is new wires, coil, cap, rotor. The ignition module is the same one that powered the 400 in the '79, tested fine. When I put the timing light on number one, it some times blinks twice in a row and sometimes only lights up about 1/2 the time or less. It backfires through the carb like it is way out of timing, I checked firing order.
Any ideas, I'm only 23 and lossing my hair over this.
Old Apr 2, 2006 | 06:54 PM
Torque1st's Avatar
Torque1st
Posting Legend
How many miles on the 460? Have you tested the distributor pickup module?
Old Apr 2, 2006 | 07:50 PM
heathkiks's Avatar
heathkiks
The engine has about 60,000 original mi.
How do I test the pickup module?
Old Apr 2, 2006 | 08:08 PM
Torque1st's Avatar
Torque1st
Posting Legend
Take it to a parts store, move the wires during testing. The wires often break which causes the problems you have observed when the vacuum advance mechanism moves the distributor plate.
The timing chain needs to be replaced on those engines at 80K miles and yours may need it just from age.
minnesotafisherman
Sep 7, 2012 08:56 PM
tractoman
Jul 27, 2010 06:29 PM
royt911
1983 - 2012 Ranger & B-Series
Nov 17, 2009 09:31 AM
Art
18
Dec 9, 2007 09:36 PM
arsleuthster
Dec 19, 2004 12:55 PM
