2004 Black Explorer... white stripes
Old Apr 2, 2006 | 02:55 PM
tyguy's Avatar
tyguy
Hey Guys,
I just bought a fully loaded black Limited, '04. On both sides of the X there is a really fine tape that came factory. ( I hope this makes sense). It is two fine lines of white tapelike material that go from the front of the car to the back right about door handle height. Does anyone have any experience removing this tape without damagaing the paint? Any recommendations?
Thanks!
Old Apr 2, 2006 | 06:50 PM
E-150's Avatar
E-150
Here you go:
<table cellpadding="0" cellspacing="0"><tbody><tr valign="top"><td align="right" valign="top">1. </td> <td> Heat the stripe with a hair dryer. </td> </tr> <tr valign="top"> <td colspan="2"> </td> </tr> <tr valign="top"> <td align="right" valign="top"> 2. </td> <td> Peel the stripe slowly, pulling it off at a 90-degree angle while heating the next section. Do not overheat the paint, or it will be more likely to chip. </td> </tr> <tr valign="top"> <td colspan="2"> </td> </tr> <tr valign="top"> <td align="right" valign="top"> 3. </td> <td> Use a plastic putty knife if you don't have long fingernails, but be careful not to scratch the paint. </td> </tr> <tr valign="top"> <td colspan="2"> </td> </tr> <tr valign="top"> <td align="right" valign="top"> 4. </td> <td> Put some multipurpose cleaner and lubricant, such as WD-40, on a scrubbing pad (the type with a net covering) and rub off the leftover adhesive. </td> </tr> <tr valign="top"> <td colspan="2"> </td> </tr> <tr valign="top"> <td align="right" valign="top"> 5. </td> <td> If the stripes are old, they may not peel off easily, even with heat. Soak them with WD-40 for 15 minutes and then try scraping. </td> </tr> <tr valign="top"> <td colspan="2"> </td> </tr> <tr valign="top"> <td align="right" valign="top"> 6. </td> <td> Wash the car thoroughly with mild soap. </td> </tr> <tr valign="top"> <td colspan="2"> </td> </tr> <tr valign="top"> <td align="right" valign="top"> 7. </td> <td> Wax and enjoy!</td></tr></tbody></table>
Now if your going to add new pinstriping, add some red. Red and black look awesome together.
Old Apr 2, 2006 | 07:09 PM
srercrcr's Avatar
srercrcr
One thing that wasn't mentioned.....the stripe hid the sun hitting the paint, so you may be a change in luster. To get it right you may need to polish out with compound then have it clearcoated.
Old Apr 2, 2006 | 07:28 PM
tyguy's Avatar
tyguy
awesome guys.. yeah I found the answer on another site before I read your post but a hair dryer and some rubbing alcohol did the trick. it is amazing what removing the pinstripes does for appearance.
Thanks again!
maxwell18
Aug 17, 2012 10:18 AM
srteach
May 30, 2012 06:29 PM
1buckeyefan
Jan 18, 2011 01:29 PM
adkinsca
1983 - 2012 Ranger & B-Series
Apr 16, 2002 01:06 PM
RangerJoe
Mar 29, 2002 01:41 PM
