mooneyes gauges
Old Apr 2, 2006 | 10:47 AM
tgowers's Avatar
tgowers
mooneyes gauges
i just installed a mooneyes oil pressure and a fuel level gauge. the oil pressure shows the pressure maxed out... could a bad ground cause that? i wired it directly to the oil pressure sending unit, and its getting power from the fuse box. when i turn the ignition on it jumps up to about 75 psi with the motor not running. does that sound like a bad ground? that's all i can figure. thanks for the help.
-tgowers
mooneyes1
Oct 28, 2008 10:49 AM
tgowers
Nov 29, 2006 04:42 PM
tgowers
Jan 29, 2006 09:59 AM
tgowers
Dec 31, 2005 05:31 PM
mooney456
Apr 22, 2005 10:15 PM
