300/FE 4 spd
Old Apr 1, 2006 | 11:58 PM
10MPG's Avatar
10MPG
300/FE 4 spd
I've just brought home a ratty little'77 shortbed,300/3spd in floor.I've got an old '67 3/4 w/360,4spd(motor junk).How hard of a swap to put the "granny gear" behind the 300?
Old Apr 2, 2006 | 12:08 PM
rusty70f100's Avatar
rusty70f100
The bellhousing wont bolt up. Different pattern. I'd build up the 360 to a 390 and swap both the motor and transmission over. More power that way...
Old Apr 2, 2006 | 08:11 PM
10MPG's Avatar
10MPG
The truck isn't worth the trouble,I was hoping I could swap out the trannies and leave the bell attached to the engine.So the 3 spd and the 4 spd's have a different pattern for the bell at the front?
Old Apr 3, 2006 | 09:30 AM
Mike G's Avatar
Mike G
Crawl under there and size the two up. Take your standard measurements, like from front of trans to tail shaft end and compare the two. What is the trans code off of the door of the 77? I would say you should be about 99% good for a direct swap, there weren't too many trannys used in that time span that didn't just bolt right up from one to the other.
--Mike
Old Sep 22, 2006 | 05:05 PM
Shanemorris321's Avatar
Shanemorris321
300 and 3023 use same bellhousing i did it on a 65 f100 and a 62 f100
Old Sep 27, 2006 | 12:42 PM
hoxiii's Avatar
hoxiii
IIRC, the 3 speed bellhousing has a narrower pattern where it bolts to the trans than the 4 speed does. But, just yank them both out and look, see if they're the same.
If they aren't, just get a 300/302/351 bellhousing from in front of a 4 speed, bolt it up and go.
Justin
Bulldawg1081
Mar 13, 2013 08:09 PM
Fordguy_1970
Sep 7, 2010 12:19 AM
thunderb
Aug 12, 2005 07:36 AM
Brown89f150
May 8, 2004 04:32 PM
idealtrucks
Sep 16, 2002 07:08 AM
