Daily driver
Old Apr 4, 2006 | 06:28 AM
OzFTrucker's Avatar
OzFTrucker
"Brill" may be British but Ive haven't heard it in oz for 20 years and even then it was only used by 10 y.o kids.
Old Apr 4, 2006 | 12:39 PM
19604x4's Avatar
19604x4
No fee to use the historical info I used. I contacted John by phone and he responed in 3 days to my email address and had the info. I was very pleased with the response time and more importantly with the fact that it helped me to convice the motor vehicle branch that the vin# was valid.
No harm in trying.
I'll have to eat crow, since my wife firgured it meant brilliant.
Old Apr 4, 2006 | 03:15 PM
Col Flashman's Avatar
Col Flashman
Well how bleedin' marvy for you, olde son , as I've friends in Canberra & it's used there all the time.
Old Apr 21, 2006 | 10:42 PM
factory594x4's Avatar
factory594x4
how did you find out how many were produced that year?
Old Apr 22, 2006 | 11:49 PM
19604x4's Avatar
19604x4
how many
I contacted the gentlemen below:
JOHN ALBANO
Ford CRC Historical Consultant
Tel: (905) 845-2511 Ext. 1428
Fax: (905) 844-1198
I live in Canada and my 60 truck was built in Canada. I am not sure if this will work if you have a US made truck. Hope this helps.
Old Apr 24, 2006 | 11:11 AM
idaho211's Avatar
idaho211
I have a 59 1/2 ton 4x4 and it has 3.90 gearing on the ford 9 inch rear. I think the 223 six would be good for around town daily driving and offroad. I don't know if you are going to tow what kind of power you are going to have. I would keep the current dana spicer 24 t-case. I have a friend that has had great luck with them and has had over 250 thousand miles on them. I would make sure though that the U-joints and splines are in good shape since you have 3 drive shafts to contend with and especially if your truck has been raised. I would like to see one of these old trucks going to work. It would make my day. Good luck.
Old Oct 11, 2006 | 09:54 PM
jbbmw's Avatar
jbbmw
good mileage with a built 292
My '59 F 350 with a 292 4 speed and 5.14 gears was only getting about 8 MPG, so I mounted a 3 speed backwards behind the 4 speed. Now when I'm on the freeway in 4th, 1st, at 75MPH, the engine is at 1500 RPM. And 15 MPG. I just used what I had to get 6 speeds. diesel john
Old Oct 12, 2006 | 08:05 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by Col Flashman
He extremely correct about the 223 I-6, you simply can not miss the this I-6 engine, great relyability, low end fpt where & when you need it, average 25mpg w/ Hwy use.
Colonel, I know you're dedicated to the sixes but I have never seen a 223 in a stock truck, stock 2x4 drivetrain that turned in more than high teens mpg. I had a 53 with rebuilt 6 and on the flat prairies of Illinois it never did better than 15 mpg, back in the days of the double-nickel (stock 3-sp, no OD). Are you using magnets on your gas line, or what?? or are you talking metric (kpg)? Even with OD, I would not expect a 4x4 to do better than 18 or so. Not even the modern EFI trucks can do much more than that.
Old Oct 12, 2006 | 08:37 AM
Nuthin's Avatar
Nuthin
As much as I love my stock 223 2X4, I have to agree: the best I ever saw out of it was high teens when it was my daily driver. That's with a 3-sp and OD. I was one of the people who never objected to the Double Nickel since Old Horse topped out just around 55MPH on a good day. I might hedge a bit if the Col says he re-geared. Mine runs the 4.10 rear end.
Old Oct 12, 2006 | 10:07 PM
idaho211's Avatar
idaho211
I didn't catch did it have a 3 speed or 4 speed?
I did some calculating and if he has a 4 speed and running 31 inch tires his rpm at 60 mph would be 2500 rpm and if 70 mph over 2900 rpm.
If you are running smaller tires of course the rpm would be higher.
I based this on you having the 9 inch ford differential with 3.89 gears which were standard for 1/2 ton 4x4
I don't know if you have to travel on the interstate for a daily commute which would make you a little slow.
Plenty of power for offroading and I agree that the Spicer 24 case is rock hard
and it is good you have manual hubs. Let me know if you need with 4x4 stuff. I am working on a 60 3/4 ton 4x4.
Old Oct 13, 2006 | 02:35 AM
Col Flashman
Father achieved those numbers, In U.S. M.P.G. on average, w/ a 3-on-the-tree, 3.70 rear gears, 9" ford differential & running 7.10x15"LT tires, Cruising @ 65 MPH on the Hwys/Fwys in Southern California, N.M., Colorado, Nevada, Texas.
Plus he did all his own tweeking & wouldn't let anyone else touch his work afterwords.
That's the milage I achieved w/ my 223c.i.er, w/ an almost indentical set-up, before swapping it out for the 300c.i.er.
Are you talking about a Falthead/L-6, a 213 I-6 or the 223 I-6 in your '53 & is it the stock engine that came w/ the "Olde Girl"?
Because there's are some difference between any of the afore mentioned & the 223 I-6 from 1960.
Believe it or not, no skin off my nose.
docfroggie
2009 - 2014 F150
Jul 17, 2011 12:01 PM
shobbs64
6.4L Power Stroke Diesel
Mar 17, 2011 03:07 PM
kent521
Mar 11, 2011 09:46 AM
GrayRanger4x4
Georgia Chapter
Sep 7, 2003 06:04 PM
neeks1
Oct 10, 2001 09:37 PM
