Side tank
Old Apr 1, 2006 | 11:01 AM
71f-250's Avatar
71f-250
Side tank
It seems that my side tank doesnt want to work. Not the main one in the cab.
I finally got the old locking cap off [the PO never gave me the key]
And I filled it with a few gallons.
I flip the switch and the truck will run out of gas, flip back to the regular tank it runs fine.
I looked underneath and it looks like all the hoses are connected.
Is there a union that I can remove to clean out?
Or does the tank have to come out to do any cleaning?
Old Apr 1, 2006 | 12:11 PM
mikesf100's Avatar
mikesf100
id go for the cleanout option, also check you switch
Old Apr 1, 2006 | 12:33 PM
Fomoko1's Avatar
Fomoko1
Check the fuel line coming out of the rear tank for obstruction by unhooking it at of the bottom of the tank. Most likely the problem is in the tank in which case it will have to come off and could very hard to clean depending on the design of the tank. A rad shop should be able to clean it but it could be costly.
It could be a plugged side of the valve, something to check but most times the tank is plugged with rust.
Old Apr 1, 2006 | 12:56 PM
Knight70F250's Avatar
Knight70F250
Are you using the switch on the floor to the left of the seat? (Not the one on the dash) You probably are, since you said that you looked underneath, but for clarification, the dash switch is for the sender to the guage, the floor switch is for the tanks.
Old Apr 1, 2006 | 01:56 PM
Fomoko1's Avatar
Fomoko1
Good point, one that I never though to explain.
BaronVonAutomatc
Nov 24, 2014 05:53 PM
El Camino Man
Feb 25, 2013 05:49 PM
1996F250
Jan 15, 2007 03:06 PM
1996F250
New Member Introductions
Jan 15, 2007 11:42 AM
DeenHylton
Computer Chips & Tuners
Dec 5, 2000 07:58 PM
