engine miss
Old Jan 15, 2007 | 11:30 AM
1996F250's Avatar
1996F250
engine miss
I Have a 1996 F 250 with 5.8 gas burner. The truck will idle fine. As I start down the road it will begin to miss and sputter like it is running out of fuel. If I am on the front tank I can flip to the back tank and immediately flip back to front tank and the truck will run like new for about 1/4 mile then start the process back over. As long as I will flip tanks back and forth the truck will continue to run ok.
Old Jan 15, 2007 | 11:42 AM
Fomoko1's Avatar
Fomoko1
Welcome to FTE.
Browse thru the FTE list of forums and chapters from this link: https://www.ford-trucks.com/forums/index.php
Drop into the Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) forum and the 1987 - 1996 F150 And Larger F-Series Trucks
Don`t forget to check out your local FTE chapter.
kenaijoe
New Member Introductions
Jan 27, 2008 10:29 AM
rieskamg
Oct 9, 2007 02:13 AM
wolfeelz
Jun 17, 2007 11:28 PM
rzuehlke
Mar 26, 2007 12:22 PM
91 fordman
Mar 1, 2007 03:46 PM
