Sponsored by: Innova
ford amplifier bypass?
Old Apr 1, 2006 | 12:23 AM
69ford99's Avatar
69ford99
I have a '96 Bronco with the premium sound system and want to put an aftermarket cd player in. I got the amplifier bypass harness so I can use the built in amp from the cd player. The directions say to unplug the input/output from the amp and plug in the bypass plug. I plugged in the plug from the input but the only output would be the little square plug I pulled from the back of the factory cd player. The other side of the bypass plug doesn't match the little square plug, also I have another harness it came with which plugs into the factory cd player plug and makes a pigtail to hook up the aftermarket cd player it has the little square plug for the factory amp. So do I have the wrong bypass plug or am I just an idiot? Oh if it helps its a metra part # 70-5514
Old Apr 1, 2006 | 01:48 AM
IPACA9's Avatar
IPACA9
I think you need the amp eliminator plug Metra #70-5513
Old Apr 1, 2006 | 09:11 AM
fordboy_52's Avatar
fordboy_52
hey kc, can you make a post with all the bypass kits and then ill close it and put it in the tech folder?
thanks
ill even link u, or u can link u...
Old Apr 1, 2006 | 09:18 AM
69ford99's Avatar
69ford99
Thats the plug I got. One side plugs in but the other side I can't find.
Old Apr 2, 2006 | 12:40 AM
69ford99's Avatar
69ford99
I went to the stereo shop and talked to the install guy and he said don't use the bypass, just hook up the harness and the factory amp plug to the cd player and hook up the blue amp wire on the harness. I did that and it works but am curious if my speakers are being amplified but the factory amp, the amp in the cd player, or both.
Old Apr 2, 2006 | 01:05 AM
IPACA9's Avatar
IPACA9
The way your install shop is describing is that they are powering the factory amplifier and using it to run your speakers.
The bypass should be a no-brainer. The amp should have matching plugs that allow you to unplug it and plug them into your bypass harness. If this is not the case then you will have to hardwire past the amplifier.
Here's some wiring info I could find. These wires for the speakers should match up on the output side of the amplifier.
<TABLE borderColor=#d3d3d3 cellSpacing=0 cellPadding=0 width=635 bgColor=#ffffff border=1><TBODY><TR align=middle height=18><TD class=directwire_heading width=135>Radio 12v
</TD><TD class=footer> lt. green/purple
</TD><TD class=footer align=middle width=135> +
</TD><TD class=footer width=130> radio harness
</TD><TD class=footer align=middle width=100>
</TD></TR><TR align=middle height=18><TD class=directwire_heading width=135>Radio Ground</TD><TD class=footer> black and black/lt. green </TD><TD class=footer align=middle width=135> - </TD><TD class=footer width=130> radio harness </TD><TD class=footer align=middle width=100> </TD></TR><TR align=middle height=18><TD class=directwire_heading width=135>Radio Ignition</TD><TD class=footer> yellow/black </TD><TD class=footer align=middle width=135> + </TD><TD class=footer width=130> radio harness </TD><TD class=footer align=middle width=100> </TD></TR><TR align=middle height=18><TD class=directwire_heading width=135>Radio Illumination</TD><TD class=footer> lt. blue/red (dimmer) </TD><TD class=footer align=middle width=135> + </TD><TD class=footer width=130> radio harness </TD><TD class=footer align=middle width=100> </TD></TR><TR align=middle height=18><TD class=directwire_heading width=135>Factory Amp Turn-on</TD><TD class=footer> </TD><TD class=footer align=middle width=135> </TD><TD class=footer width=130> </TD><TD class=footer align=middle width=100> </TD></TR><TR align=middle height=18><TD class=directwire_heading width=135>Power Antenna</TD><TD class=footer> </TD><TD class=footer align=middle width=135> </TD><TD class=footer width=130> </TD><TD class=footer align=middle width=100> </TD></TR><TR align=middle height=18><TD class=directwire_heading width=135>LF Speaker +/-</TD><TD class=footer> orange/lt. grn - lt. blue/wht </TD><TD class=footer align=middle width=135> +,-</TD><TD class=footer width=130> radio harness or amp below radio </TD><TD class=footer align=middle width=100> </TD></TR><TR align=middle height=18><TD class=directwire_heading width=135>RF Speaker +/-</TD><TD class=footer> white/lt. grn - dk. green/org </TD><TD class=footer align=middle width=135> +,-</TD><TD class=footer width=130> radio harness or amp below radio </TD><TD class=footer align=middle width=100> </TD></TR><TR align=middle height=18><TD class=directwire_heading width=135>LR Speaker +/-</TD><TD class=footer> pink/lt. green - tan/yellow </TD><TD class=footer align=middle width=135> +,-</TD><TD class=footer width=130> radio harness or amp below radio </TD><TD class=footer align=middle width=100> </TD></TR><TR align=middle height=18><TD class=directwire_heading width=135>RR Speaker +/-</TD><TD class=footer> pink/lt. blue - brown/pink </TD><TD class=footer align=middle width=135> +,-</TD><TD class=footer width=130> radio harness or amp below radio </TD></TR></TBODY></TABLE>
Old Apr 2, 2006 | 07:51 AM
69ford99's Avatar
69ford99
Your in Independence thats not too far from me...Anyway which is better using the factory amp or the one built in to the cd player?
Old Apr 2, 2006 | 10:23 AM
IPACA9's Avatar
IPACA9
I like the radio amplifier personally. You get the great sound that is actually coming from the radio and not filtered through the factory amplifier which gives you the same sound you had before. If you like the way your audio sounds but wish to just have more features then keeping the amp is fine.
I see you're in Kansas City. Feel free to hit me up. My number is on the website.
