pre-combustion chambers
Old Mar 30, 2006 | 03:56 PM
sosotwo's Avatar
sosotwo
I picked up a used 6.9 to replace the one in my truck.
I figured I should pull the heads to see how every thing looked to my suprise there is no pre combustion chambers in it??
whould that run right?
it sure don,t look right to me it looks like it burn't part of the head gasket and maybe bypassing antifreeze.
Is it good or bad to run like this?
Old Mar 30, 2006 | 04:50 PM
bilder12's Avatar
bilder12
the pre cup chambers are part of the head. If they arent in the heads, there shoudl be one helluva hole per cylinder in the heads. I doubt if they will run without the chambers. Sounds like ya got to get the heads checked too, if it has symptoms of blown headgaskets.
Old Mar 30, 2006 | 05:45 PM
PLC7.3's Avatar
PLC7.3
Yes they will run but smoke like hell, the lack of the Pre cups means there was no real combustion chamber seal to the cylinder. The pre cups seal the top half of the head gasket area of the fire ring. Cracks in the precups beyond the fire ring is usually bad enough to cause problems, missing completely is way..way out there.........
I would say as above get the heads checked over and get new precups.. get this done by a AERA associated shop. There are special instructions for the precup to head levels and max/minimums on the head refacing. Need more email me........
Old Mar 30, 2006 | 08:08 PM
sosotwo's Avatar
sosotwo
thanks for advice I will let you know how things work out
Lakerat
Feb 2, 2011 12:35 PM
logan.hawes
Jun 24, 2010 03:43 PM
tcr1016
Oct 21, 2009 07:03 AM
mohojohn
31
Jul 30, 2009 04:05 PM
foggy_2
Mar 18, 2002 04:08 PM
