240 or 300 head identification
Old Feb 2, 2011 | 10:16 AM
Lakerat's Avatar
Lakerat
I need help identifying a couple heads. I am rebuilding my 77 300, and I have a spare head off of an 82 300. The heads are identical with the exception of the combustion chambers. The head on the 77 300 I am rebuilding, has a D shaped combustion chamber, and the head on my spare 82 300 has a kidney shaped contribution chamber. Is it possible that some 300 heads had the kidney shaped combustion chambers. The casting # on the spare head with the kidney shaped chamber is too distorted to make out.
Old Feb 2, 2011 | 12:08 PM
F-250 restorer's Avatar
F-250 restorer
Without a doubt, the kidney bean shaped chambers are on a 240 head. Using a stock 240 head on a 300 is a trick a lot of builders use to boost the compression a bit, about a half point. If you put a 240 head on a 300 with 9.0:1 compression, it will be raised with the 240 head to 9.5:1. If the head has been milled, then the c.r. will go up, depending how much it was shaved.
That's a nice find.
Here is a 300 chamber:
And here is a 240:
Old Feb 2, 2011 | 12:35 PM
Lakerat's Avatar
Lakerat
Thanks!
I was hesitant to believe it was a 240 because it came off of my spare 1982 300 from a F350 truck, also the head has the bumps in the exhaust ports, and I read somewhere the 240 head had a temp inlet, which this one dose not.
trozei
40
Sep 12, 2020 09:22 PM
Old Yblockman
May 4, 2017 08:18 PM
Anderson80
Feb 25, 2017 07:42 PM
john mullen
Aug 16, 2015 01:45 PM
biggman70f100
17
Jun 21, 2006 01:59 PM
