code p0279 help
Old Mar 30, 2006 | 03:51 PM
graderman's Avatar
graderman
code p0279 help
I just had my 1995 f-250 power stroke with 225 000 km on it scannned it give me the codes p0279 p0472 with truck shut off and p1111 with truck running can anyone tell me what these mean
thanks
Old Mar 30, 2006 | 04:00 PM
1997F-350's Avatar
1997F-350
0279 INJ Injector circuit low - Cylinder 7 FMEM mode, engine will run on 4 cyl. Harness short to ground
0472 EBP Exhaust press sensor circuit low input Disables back pressure device Open/grounded circuit, biased sensor, PCM
1111 N/A System pass No PCM system faults detected N/A
Old Mar 30, 2006 | 04:03 PM
Tx_Atty's Avatar
Tx_Atty
P0279 Cylinder 7 Injector Circuit Low;
P0472 Exhaust Pressure Sensor Low;
p1111 System Pass (No DTCs Available)
beat me to it.
Old Mar 30, 2006 | 04:20 PM
graderman's Avatar
graderman
where is the exhaust pressure sensor located
Old Mar 30, 2006 | 09:26 PM
tjbeggs's Avatar
tjbeggs
ebp sensor is right behind the high pressure oil pump reservior and in front of the filter assembly toward the passenger side. it has a small tube running down to the exhaust manifold. this doesn't ussually cause the cel to come on nor does it casue drivablilty problems. the p0279 on the other hand will cause problems.
ItsMREMT
Nov 8, 2024 09:34 PM
jleworthy
Apr 26, 2017 03:24 AM
bradsamcarp
Mar 7, 2011 07:39 PM
PRDATOR
Feb 27, 2010 05:15 PM
MucksUnlimited
Jan 10, 2009 05:46 PM
