Aerostar Ford Aerostar
engine dies at abrupt stops
Old Mar 30, 2006 | 10:43 AM
tmo1717's Avatar
tmo1717
93 aerostar will operate fine except when the van is stopped
abruptly.(does not seem to matter the time
the van has been driven)then ,after stopping the engine dies and can not
be restarted. the engine when restarting will crank fine
but does not turn over.after the vehicle sits for a few hours the van will
start normally.
Old Mar 30, 2006 | 11:55 AM
copper_90680's Avatar
copper_90680
Hi Tmo1717:
Welcome to our FTE forum
When you say "the engine when restarting will crank fine but does not turn over," what does it mean? Usually, when the engine is cranking, then it must be turning over. I'm not picking on the post, but just want some clarification. Do you mean the engine will crank and turn over fine, but will not start?
Did you try to pull the stored code from the computer? Most autopart stores will do it for free.
From what you described, all I can say is that you might be having an intermittent problem with the ignition system, probably the ignition module, but that's just a guess and you don't want to replace components haphazardly since it can be pretty expensive very quickly.
Regards
Old Mar 30, 2006 | 12:16 PM
tmo1717's Avatar
tmo1717
engine cranks but does not start after the engine dies. repeated start attempts
produce exact same results. van will start fine after a few hours of "rest" but usually
not earlier. only happens on abrupt stops ..
Old Mar 30, 2006 | 12:39 PM
copper_90680
Read any stored codes first. Here is how, compliment of 93nighthawk, best write-up ever
https://www.ford-trucks.com/forums/s...86&postcount=3
Old Mar 30, 2006 | 12:52 PM
tmo1717's Avatar
tmo1717
appreciate your nice reply. and any ideas as to fuel filter or fuel pump issue
with aerostars and this sudden engine problem??
Old Mar 30, 2006 | 01:05 PM
copper_90680
If the problem is your fuel filter, then it would happen when the car is under heavy load, not when you try to stop.
The fuel pump is a possibility, but why at a sudden stop, unless the stopping knocks a connector off. But then it won't start again after cooling down for a few hours.
If you pull the code, it might help pinpoint the problem instead of us guessing around.
Old Mar 30, 2006 | 03:13 PM
Lance1601's Avatar
Lance1601
Camshaft position sensor? I heard it could happen.
Old Mar 30, 2006 | 03:24 PM
copper_90680
'93 Aerostars do not have camshaft position sensors. If it's 3.0L then it has a distributor. If it's a 4.0L then it has a crankshaft position sensor.
Old Mar 30, 2006 | 09:00 PM
yendor's Avatar
yendor
sounds more like vaccum or IAC
mahd776
Jan 30, 2014 06:20 AM
maldbwmjr
Nov 16, 2008 02:51 PM
kingnine
Aerostar
38
Oct 21, 2007 05:53 PM
sd2734
May 18, 2006 02:14 PM
nungester
Jul 10, 2005 11:38 PM
