Who's Running a Small Block?
Old Mar 30, 2006 | 08:06 AM
lakecityg's Avatar
lakecityg
?? Looking at a Blown 347 compared to a 390FE motor in my 1954 F-100. If the truck had each engine run down the track, which would perform better? Only interested in racing the truck, and street rodding.
Old Mar 30, 2006 | 08:13 AM
fatfenders's Avatar
fatfenders
The 91 Stang in your signature is obviously blown, so you know the answer to your question. Is the 390 stock? If so, this isn't even going to be close. You can make a 2.3L Pinto engine faster than a naturally aspirated 390 if no technology or budget constraints are placed on the comparison.
Old Mar 30, 2006 | 08:53 AM
lakecityg's Avatar
lakecityg
ok. let me be clearer. if the 390 was built it still seems that the 302 based motor will outpeform it, using similar budgets. i say this because the stock motors are similar in horsepower. am i wrong or right. please correct me if i am. racewise. maybe not from a torque aspect but like I said b4. in the quarter it seems that it would.
Old Mar 30, 2006 | 02:07 PM
AXracer's Avatar
AXracer
If they were both built the 302 would be quicker due to less weight. The 390 would likely accellerate quicker tho.
Old Mar 30, 2006 | 02:14 PM
Ringo Fonebone's Avatar
Ringo Fonebone
Hard to compare. You can build an FE into one heck of a beast with the right heads, stroking it out, etc
I have heard of twin turboed FE's even... and top of the line Eleanors run a blower..
But I bet the horsepower costs you dear compared to a smallblock. Speed parts are much more common for them.. so I'd say dollar for dollar the Windsor is gonna make more horses
Old Mar 30, 2006 | 03:04 PM
lakecityg's Avatar
lakecityg
great, then we are on the same page. i am thinking a blown 351, ported heads and so on will get me in the 12's. possible? and what about the swap from the current 390 to a small block? would i need to use a c4 instead of the current c6??? or find a race type aod??
Old Mar 30, 2006 | 03:15 PM
Ringo Fonebone
I have a c6 behind a 351W on my '63
and an E40D behind a 302 in my '64
Old Mar 30, 2006 | 03:45 PM
lakecityg's Avatar
lakecityg
what is the difference between a c4 and a c6? would one be better for my application?
Old Mar 30, 2006 | 04:20 PM
Ringo Fonebone
C4 is a more light-duty transmission.
Behind a blower I'd say you need a built c6
Old Mar 30, 2006 | 04:29 PM
fatfenders's Avatar
fatfenders
C6 is much heavier.. a bad thing for a drag car. But it would take some serious upgrading to get a C4 ready for duty behind a 500+ HP 347. And back to your original question. I'm with Ringo. You'll need a fat wallet to get a 390 to put out the performance of a blown 347. SB parts are WAY cheaper. As you are probably aware though, your 347 will be well into the "split the block" power level zone. An FE may not be IMO.
Old Mar 31, 2006 | 06:49 AM
svooom's Avatar
svooom
C4's are relatively bullet proof if you rebuild them using good components. I've got a friend running close to 700hp through one with no problems.
As for the 1/4 mile ET's. You can get into the 12's with as little as 300hp if you set your truck up right. I've got a '84 Mustang with a 351 crate motor (380hp) and a 5 speed and I run high 12's all day long and that is with suspension set up for autocross and street tires. It would drop even more if it was set up for drag racing. With a good set of sticky meats, a well tuned suspension, and a high stall converter in your C4 you can pull of some really good times with modest horsepower.
Old Mar 31, 2006 | 07:05 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I'd stick with the C6 if you're going racing. It has much heavier duty internals than the C4.
Vern
Old Mar 31, 2006 | 07:59 AM
51dueller's Avatar
51dueller
You can build up a C-4 to the strength of a C-6. Some guys use a C-4 behind a built 460.
Shattered
Aug 31, 2014 07:08 PM
Patrick714
May 30, 2014 05:23 AM
MisterCMK
Sep 24, 2012 08:58 AM
Iallwork
Jan 9, 2011 10:36 PM
whitesell54
43
Aug 18, 2010 11:15 PM
