running rough
Old Aug 31, 2014 | 12:45 PM
Shattered's Avatar
Shattered
running rough
Replaced injector and pedestal o-rings and now truck is running rough, runs like it has a soft miss. no check engine light.
Any ideas?
Old Aug 31, 2014 | 01:30 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Needs to be driven hard to purge the air out of the system.
Old Aug 31, 2014 | 01:48 PM
Shattered's Avatar
Shattered
Sorry guys, I didn't do injector O-rings, I did pedestal and turbo o-rings. I don't know why I said injector. anyway the truck is running rough at idle, down on power and sounds like it has a soft miss. with no check engine light. truck is completely stock other than exhaust. stock pedestal, turbo the whole 9. I am looking at injector harness now and doing the 25 cent mod. any other ideas? IPR maybe?
Old Aug 31, 2014 | 01:52 PM
AllaboutMPG's Avatar
AllaboutMPG
any way to check for codes? Have AE?
Old Aug 31, 2014 | 01:56 PM
Shattered's Avatar
Shattered
No way to check codes. No AE.
Old Aug 31, 2014 | 05:35 PM
c mobley's Avatar
c mobley
does it only do this at idle and also how much fuel is in your tank if its less than 1/4 you might have the problem I had and the black foot broke off the lift pump in the tank.
Old Aug 31, 2014 | 06:03 PM
F350-6's Avatar
F350-6
Check to make sure the baby's but is in place correctly on the back of the turbo. If the pin isn't in the hole, it will cause an exhaust leak that leaves you low on poer.
Old Aug 31, 2014 | 07:08 PM
Shattered's Avatar
Shattered
Ok. There was about 1/8 tank of fuel when this started. The turbo is all lined up no exhaust leak. Did the 25 cent mod. Just waiting to hear back as to whether that worked or not.
Clay Hitchcock
Apr 18, 2018 12:21 PM
ZachH
Mar 2, 2017 07:01 PM
1_BIGMOFO
Jan 9, 2012 03:40 PM
ruffneck22
Apr 6, 2010 08:15 PM
Uncle Shank
Dec 17, 2009 04:21 PM
