Bronco II Ford Bronco II
Duraspark VS MSD?
Old Mar 29, 2006 | 08:45 PM
v8xploder's Avatar
v8xploder
Duraspark VS MSD?
I hear alot of good things about the Duraspark Conversion, but has anyone installed a MSD setup on an 2.8 BII? I hear so many things on how well MSD ignition systems work. Does any one know which would be better? Pros/Cons? Im sure the MSD setup is more expencive but It might free up a few horses/MPG's. Anyone??
Old Mar 30, 2006 | 09:16 PM
Bdox's Avatar
Bdox
The duraspark II is a perfectly good ignition system.
MSD stand for multiple spark discharge. It fires the plugs a number of times instead of just once. For average driving with a stock engine, duraspark is all you need. High performance, high rpm motors benefit from the MSD because it increases the chances of burning all the fuel. Some people claim performance and economy gains from using MSD units on daily drivers too.
Old Mar 31, 2006 | 04:25 PM
rebocardo's Avatar
rebocardo
imo, For most people the "blue" Duraspark conversion. Easily replaced components and an extra module cost less then $20 and you can keep it in the glove box.
Old Mar 31, 2006 | 08:14 PM
v8xploder's Avatar
v8xploder
"blue"? I guess I could be little confused on the duraspark conversion. Would it be too much to type if I asked what exactly it is and what parts it consists of? Is it like changing points and condencer to an electric module? Or is it more complex than that? Thanks!
Old Mar 31, 2006 | 08:18 PM
Bdox's Avatar
Bdox
It's easy. The "blue" simply refers to the color of the grommet on the recommended ignition control box. You need that, a duraspark distributor that fits your truck, the correct coil and the harness. You can probably get the whole setup from a salvage yard. And maybe from ebay.
Old Mar 31, 2006 | 08:25 PM
v8xploder's Avatar
v8xploder
Now when you say a different harness, as in just to the distributor and you wire it in the the factory wiring? or an complete wiring harness for the ign. system. im kind of having a hard time getting a good grasp on this. I do know that the duraspark distributors are on late 70's ford 2.8 engines, correct? how can you tell the difference between an duraspark and a regular dist.?
Old Apr 2, 2006 | 01:30 PM
idfergusson's Avatar
idfergusson
A Duraspark distributor will have 3 wires coming out of it, they should be orange, purple and black and will come together at a connector about 6-8 inches from the distributor and on the side of the distributor will be a vacuum advance cannister.A TFI distributor will have the ignition module attached to the distributor and no vacuum advance cannister.I am not sure if they ever used a points style distributor on a 2.8 but if you find a distibutor with a vacuum cannister and a single wire coming out the side then pop the cap to make sure it doesn't have points.I took a different route on my 2.8, I used a Duraspark distributor and a GM HEI module.That way I could keep the stock TFI style coil and the wiring was a bit easier as you don't need to run a ballast resistor.A couple of tips, the Duraspark distributor I grabbed from the wreckers had the old style cap with the female ends.I figured out that the cap adapter from a 200" 6 cyl worked on the 2.8 Duraspark distributor which allowed me to use the newer style cap with the male connectors.
Old Apr 4, 2006 | 01:44 PM
kernel-panic's Avatar
kernel-panic
My personal opinion of MSD... well, I have a MSD 6A on my '95 Nissan, and I not only got more power from my 2.4 4-cyl, but I also gained a few mpg (of course, I also put a better exhaust - header, hi-flow cat, v-force muffler, 2 1/2" piping - and a K&N filter on the thing, too).
If you seriously want to get rid of carbon buildup and actually have a cleaner, better-running engine, MSD is a good way to go. It's one of the cheaper ways, not to mention, they sell the plug-in harness so you don't have to cut and splice any wiring (at least not on a TFI Ford)
Old Apr 4, 2006 | 07:08 PM
v8xploder's Avatar
v8xploder
thats what I thought, id Much rather spend the money and get a new ( not junkyard parts) and the added bonus of Multiple spark, which would actually improve performance, mileage and reliability. Good thinkin
Old Apr 27, 2006 | 01:43 PM
rwmorrisonjr's Avatar
rwmorrisonjr
Now that you've decided to do this, do you have the part numbers needed for the MSD? I'm thinking of doing the same thing since I'm at altitude and want to get as much power out of the engine as possible.
74 F350 SCS
Dec 28, 2011 09:45 PM
74 F350 SCS
Nov 26, 2011 11:20 PM
smaki09
13
Jun 9, 2011 01:39 AM
76_F150_390
33
Aug 11, 2002 01:14 PM
