Which tranny?
Old Mar 29, 2006 | 07:53 PM
lionsden's Avatar
lionsden
Which tranny?
Decided to just rebuild my '97 Ranger's 2.3L engine and thinking of doing the tranny at the same time. Trouble is (I know this sounds dumb!) how do I find exactly which tranny I have? I called around about rebuild kits etc. today and was asked several times which one I have but I couldn't tell them. Does the VIN give any indication? All I know for sure is it is an automatic trans with Overdrive (has the button on the shift lever). Anyone know which it is?
Thanks in advance for the help,
lionsden
Old Mar 29, 2006 | 07:56 PM
lionsden's Avatar
lionsden
As a follow-up, if I decided to replace the auto trans with a manual, how much trouble and which one is best?
Thanks, lionsden
Old Mar 29, 2006 | 08:03 PM
voodood's Avatar
voodood
My 95 2.3 has the 4R44E in it and I believe the 97 has the same.
Old Mar 29, 2006 | 08:06 PM
john112deere's Avatar
john112deere
I can't answer how much trouble, although the fact that that truck was available with a manual should make it easier to find all the parts you'll need. (Pedals, hydraulics, etc.)
The manual trans that would have come in that truck is the Mazda M5OD (Manual 5-speed OverDrive). It has an integral bellhousing, and 2.3 bolt pattern is not shared with either of the other engine choices in the Ranger, so you'll have to find one that was originally behind a 2.3. It's not a great trans, but it works pretty well for this application. I got 221k on mine before the bearing started making noise.
Old Mar 29, 2006 | 08:32 PM
handyman43358's Avatar
handyman43358
The M5OD in my 91 has 315,000 miles+ on it, and it's doing alright.
You will like the manual over the automatic, just because it will make the 2.3 feel like it's got a few more *****.
If you still want to identify your transmission, you can look on the information tag either inside the driver door, and give us the trans code. We should be able to tell you what tranny you have.
Old Mar 30, 2006 | 06:05 PM
lionsden's Avatar
lionsden
If I found the correct part of the tag it says "T" under the "TR" (right next to "AXLE"). Is this the right one?
Thanks again,
lionsden
Old Mar 30, 2006 | 06:17 PM
Rockledge's Avatar
Rockledge
Tranny code "T" = 4R44E
Old Mar 30, 2006 | 06:44 PM
AlfredB1979's Avatar
AlfredB1979
Not saying that the slushbox is perfect--my 2.3L truck has the mazda tranny--but now's the time to save the swap money and put it towards a good chip.
The right chip will up the tranny shift points and put an end to sloppy shifts.
Old Mar 30, 2006 | 07:21 PM
Tiggie's Avatar
Tiggie
Why are you converting to manual? It is quite an involved process these days with all the electronic controls. I beleive the drivetrain wiring harnesses are somewhat different from an auto vs manual truck. Even with a complete parts truck, the swap is going to be anything but easy. Either buy a manual truck, or rebuild your auto.
Old Mar 30, 2006 | 11:56 PM
lionsden's Avatar
lionsden
Thats what I wanted to know!
Thanks for the advice but I didn't say I WAS going to switch to manual. I wanted to know which one and how much trouble it would be. Sounds like more than I really want to take on right now. I will probably just stay with what is in the truck now rather than doing a lot of extra work. My son will be doing most of the work along with some friends at school. The local vo-tech automotive program loves to tackle those kind of jobs. Gives the boys good experience under very capable supervision. They have done work on our other cars and really do a good job - as good as most professional shops in the area (doesn't say much for the "pros"!). Regarding the chip: are there options for that and if so, which one would be best and why?
Thanks for the info,
lionsden
Old Mar 31, 2006 | 12:01 AM
lionsden's Avatar
lionsden
PS: I'll let you know how it turns out.
lionsden
Old Mar 31, 2006 | 03:13 PM
Ag2K5Ranger's Avatar
Ag2K5Ranger
I bought my '05 with a manual just because I have read all the posts to these forums, and most are pleas for help with bad automatic transmissions. Just look at the front page of this forum. It was a no-brainer for me...
