Recall?
Old Mar 26, 2006 | 12:39 AM
powerstroke6ltr's Avatar
powerstroke6ltr
Recall?
Anyone know the specifics on the recall for 04 rangers about the frame rail/crossmember puncturing the fuel tank in a side impact? Something about the rivets not done properly or something? Also, did the 04/05 rangers come with glovebox light harnesses?
Old Mar 26, 2006 | 12:45 PM
Noble Lumpkin's Avatar
Noble Lumpkin
My 05 goes not have a harness. I will check on the TSB/Recall
The only Recall is.
<TABLE class=searchBorder width="95%" align=center><TBODY><TR><TD class=nav width="50%">Make: </TD><TD class=navBlue>FORD </TD></TR><TR><TD class=nav>Model: </TD><TD class=navBlue>RANGER </TD></TR><TR><TD class=nav>Type: </TD><TD class=navBlue>ANY </TD></TR><TR><TD class=nav>Year: </TD><TD class=navBlue>2004 </TD></TR><TR><TD class=nav>Recall Number: </TD><TD class=navBlue>04V331000 </TD></TR><TR><TD class=nav>Summary:</TD><TD class=contentText> </TD></TR><TR><TD class=contentText colSpan=2>ON CERTAIN PICKUP TRUCKS, THE FRAME MAY HAVE A CENTER RAIL SECTION FLANGE THAT WAS NOT FORMED PROPERLY. </TD></TR><TR><TD class=nav>Consequence:</TD><TD class=contentText> </TD></TR><TR><TD class=contentText colSpan=2>IN THE EVENT OF A SIDE IMPACT CRASH, THE FRAME RAIL SCOULD PUNCTURE THE FUEL TANK, RESULTING IN A FUEL LEAK. FUEL LEAKAGE, IN THE PRESENCE OF AN IGNITION SOURCE, COULD RESULT IN A FIRE. </TD></TR><TR><TD class=nav>Remedy:</TD><TD class=contentText> </TD></TR><TR><TD class=contentText colSpan=2>DEALERS WILL INSPECT THE FRAME TO DETERMINE WHETHER THE FRAME WAS INCORRECTLY MANUFACTURED. IF THERE IS A PROBLEM, THE VEHICLE WILL NOT BE REPAIRED. FORD AND THE DEALER WILL REPLACE THE VEHICLE. THE RECALL BEGAN ON JULY 19, 2004. OWNERS SHOULD CONTACT FORD AT 1-800-392-3673. </TD></TR><TR><TD class=nav>Notes:</TD><TD class=contentText> </TD></TR><TR><TD class=contentText colSpan=2>FORD RECALL NO. 04S19. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236). </TD></TR></TBODY></TABLE>
Old Mar 27, 2006 | 09:50 PM
powerstroke6ltr
My truck is an 09/04 built truck....guess I shoud call the number and see if i am included..hopefully not. Anyone know where i can get the light harness? I have the light but it had a funky plug....think the dealer could wire it up for me? At least it would come with a warranty that way....thanks!
Old Mar 28, 2006 | 10:36 AM
Noble Lumpkin
Isn't that funny. My 05 was built in 08/04.
Old Mar 28, 2006 | 01:18 PM
powerstroke6ltr
really? What options do you have on yours?
Old Mar 28, 2006 | 01:39 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
I have the full set of schematics for the 2004 Ranger from Ford; unfortunately they don't have the pigtail ready and waiting for the glove box light . I plan on adding this item and more to my FX4 Level 2; the ideal point to tie in the glovebox light will be at splice S220 or pin #5 on C2280b, both are near/at the SJB. Should these prove to be a pain to access, the power point would be a convenient alternative.
Old Mar 28, 2006 | 04:37 PM
Noble Lumpkin
I have almost everything. It is just funny your 04 was built in 09/04 and my 05 was built in08/04. Something is awry.
Old Mar 28, 2006 | 06:37 PM
powerstroke6ltr
ah. um what is the SJB? Side doorjamb? My problem is that the light requires a special connector for power....can't seem to find that at this point....Anyone know when they stopped putting in GB lights?
Old Mar 28, 2006 | 08:36 PM
CowboyBilly9Mile
SJB = Smart Junction Box, the replacement for the former GEM. The SJB is in the kick panel on the passenger side, accessable via the pull and remove door. I'm confused by your asking about a special connector; if you're looking for one waiting and ready to plug into the OEM glove box light used on 1995 - 2003 models you won't find it. As I noted earlier, you will have to splice in somewhere. I also have the schematics for the 2003 Ranger, the same ones on the CD that Ford service departments use. This appears, unless there is a goof on Fords behalf, to be the last year. Also, I wouldn't expect stripper Rangers to have this feature.
Old Mar 28, 2006 | 09:43 PM
powerstroke6ltr
I just am trying now to locate the darnded little conector that plugs into the light. I realize it won't come with wire behind it. Maybe an auto store would have it? You know, like how they have 'bullet connectors' etc?? Maybe a specialty?? What cd are you using? Just AllData or the actual cd off ebay?
Old Mar 28, 2006 | 09:54 PM
CowboyBilly9Mile
I'm using the same CD that a Ford service department would use. For an 03 Ranger or an 04 Explorer, you need connector C254, female. A Ford dealer might offer a pigtail with this connector. You might also have look here: http://www.motorcraft.com/products.do?item=23
Old Mar 29, 2006 | 12:24 AM
powerstroke6ltr
WPT-314 is all i can find pertaining to the glove box lamp but that one has 2 male leads, not female. Are there any other pigtails, perhaps under a different heading? What is special about S220?
Old Mar 29, 2006 | 12:48 AM
CowboyBilly9Mile
Splice S220 is on a timed circuit (attached to the battery saver relay); voltage is dropped after about 20 minutes or so, just like it is on the dome light and the map lights (if you're lucky and have those). It might be a PITB to access, thus the power point which is about a foot away from the glovebox might be a convenient point.
Old Mar 29, 2006 | 07:55 AM
powerstroke6ltr
Ah. Makes sense. I have the dome light, but no maps, unfortunately. The whole harness seems easy to get to though. I'll call the dealer and see if they sell the pigtail...thanks for all the help!
Old Mar 29, 2006 | 04:04 PM
wendell borror's Avatar
wendell borror
When my pops worked at ford, they shut down for 2 weeks in july for change over, they will start actually building 07's in aug of 06.
