2005 4X4 Screw with 2.5" leveling kit and BFGR 285/70/17. 35,000 miles
Noticed within the last few weeks that when I apply the brakes I'm getting a "wobble" in the steering wheel. It drives and rides fine at all speeds other than when I apply the brakes. No pulling in either direction when the brakes are applied. It can get excessive if traveling at 60 mph and have to apply the brakes hard, but only lasts until it slows to about 25-30 mph. The leveling kit and tires have been on for nearly a year now and I just had the tires balanced and rotated, which help very little, so I could not imagine it would be these two things. But I don't know. I had the front end aligned after the leveling kit was installed and I don't use the truck off road hardly at all and don't climb any curbs, etc. I plan to have it looked at but wanted some input on what to have them look at first.
Any help would be greatly appreciated. Thanks
Sounds an awful lot like warped rotors. Since you mentioned tire rotations, the lug nuts need to be torqued to 500 ft lbs. Not torqueing the lug nuts can cause rotor warp from what I have heard and read.
It is definitly warped rotors. If it is under warranty, I would have them replaced. The dealer is going to want to re-surface the rotors, which will work, but they will warp easier next time due to being thinner. Demand to have them replaced.
Do you think the dealer will try and stick me with this since I've had a leveling kit and larger tires installed? This sounds pretty pricey.
THEY SHOULDN'T. I HAD A 4 INCH LIFT ON MY 04 JEEP RUBICON WITH 33" TIRES AND MY ROTORS WARPED AND THEY REPLACED THEM AFTER THE FIRST ATTEMPT TO RESURFACE THEM, NO QUESTIONS ASKED.
Well, just spoke to the Ford sevice advisor and they will be replacing the rotors and calipers. He said that they have been getting several trucks in there with this mileage for the same reasons. I'm not a mechanic by no means but he said they are replacing them with a better improved caliper, thicker and more fins for ventilation, than the stock ones. Who am I to argue or question this as it's being done under warranty, with 900 miles left until it expires, plus a free loaner truck. But like I said earlier, he's seeing more of this same thing happening so maybe everyone should be abreast of this. Like I said, I drive quite a bit as I have 35,100 miles on an '05. Thanks again for everyone's replies to my original post.
Just a thought. pay close attention to possible "wobbling" when you first accelerate from a stop. The dealership changed the angle of the rear axle several times and I believe this is the origin. The dealership is trying different angles so I can't say yet that they aren't helping. I think the same wobble which is present at initial acceleration due to driveshaft angle (its on a tsb) causes the de-acceleration wobble... any thoughts
Tim
I got my truck back today after they installed the rotors and calipers. It's perfect again. My wobble only occured when braking. It drove fine before this fix other than the wobble. Thanks for this info. though.
