Sponsored by: Real Truck
Fox Steering Stableizer
Old Mar 28, 2006 | 09:47 PM
cc322's Avatar
cc322
Had a Fox Steering Stableizer put on last week and I would highly recommend it to anybody who was thinking of doing one. It is a single one and made a world of differance, The truck fills more controlled over bumps and just all around driving. The Fox is a split valved 50/50 nitrogen gas charged shock oposed to the factory and Rancho style oil filled shocks. The cost was around 135.00. Well worth it IMO. Heres the link go to steering / bump stop and click the 2.0 steering damper..
http://www.foxracingshox.com/fox_off...road_index.htm
Old Mar 28, 2006 | 10:14 PM
skinner00's Avatar
skinner00
i am assuming it bolted directly to the factory mounts?
Old Mar 28, 2006 | 10:24 PM
cc322's Avatar
cc322
You A.S.S.U.M.E correctly grasshopper
Old Mar 29, 2006 | 08:46 AM
locash's Avatar
locash
I'm curious which one you used, as I measured the stock unit at ~12" collapsed, and ~23" extended, neither of 2 fox units fall near these specs? Can you check and see which part number you have, and if it is indeed mounted to the same brackets as stock, or if the brackets were moved?
I need a new steering stabilizer and already have the Fox external resevoir shocks on the truck, so it would make a nice addition..
Thanks!
Old Mar 29, 2006 | 10:00 AM
beemr's Avatar
beemr
Locash...is your truck lifted, or are you running those shocks on a stock setup?
I am needing new shocks on a stock truck....
Old Mar 29, 2006 | 11:34 AM
{OF}Smiley's Avatar
{OF}Smiley
Where did you buy the stabilizer?
Old Mar 29, 2006 | 07:20 PM
BobbyDiesel71's Avatar
BobbyDiesel71
[QUOTE=cc322] Had a Fox Steering Stableizer put on last week and I would highly recommend it to anybody who was thinking of doing one. It is a single one and made a world of differance, The truck fills more controlled over bumps and just all around driving. The Fox is a split valved 50/50 nitrogen gas charged shock oposed to the factory and Rancho style oil filled shocks. The cost was around 135.00. Well worth it IMO. Heres the link go to steering / bump stop and click the 2.0 steering damper..
http://www.foxracingshox.com/fox_offroad/offroad_index.htm[/QUOTE]
more info please
exact p/n and such
pics!
Old Mar 29, 2006 | 07:46 PM
cc322's Avatar
cc322
Ok here is the direct replacement part # for the Fox steering damper #98099099A. I love this thing. I would go through this place Kar Tec Offroad.
http://www.kartek.com/test.htm Also 4 wheel parts can get them
Old Mar 30, 2006 | 07:04 AM
tps0424's Avatar
tps0424
Thanks for the info!!!
Old Mar 30, 2006 | 11:41 AM
{OF}Smiley's Avatar
{OF}Smiley
Yes, thanks for the info
Old Mar 30, 2006 | 03:55 PM
locash's Avatar
locash
Just ordered one from Kartek as well, thanks for the info, they seem like good people!
Old Mar 30, 2006 | 06:41 PM
cc322's Avatar
cc322
Your welcome you guys will love it.
Old Mar 30, 2006 | 11:43 PM
locash's Avatar
locash
If I don't love it, then what?
Old Apr 4, 2006 | 12:41 AM
locash's Avatar
locash
I received mine today, and removed my old one, but something doesnt seem right, can you measure the body of your fox unit for me? The one I received seems about 6 inches or more too long.. I'll see if I can attach some pics I took with my junky camera phone..
Old Apr 4, 2006 | 07:42 AM
mettech's Avatar
mettech
I appear have a lot of "play" in my steering. I can turn the steering wheel .5" before the front wheels start to turn. I have at least 1" of play when turning the wheel both directions. The dealership says it's within specs.
Does Fox stableizer fix this issue?
