Sponsored by: Auxito
Rear Glass
Old Mar 28, 2006 | 08:00 PM
71100's Avatar
71100
Question Rear Glass
Has Any 1 Had The Back Glass Leak? I Have A 01 F150 4x4 Super Crew
Old Mar 29, 2006 | 09:19 AM
BillyBob69's Avatar
BillyBob69
If you are sure it is the glass....just go by a window shop and see if they can re-seal it. Also check the seal on the third brake light.
Old Mar 30, 2006 | 07:51 AM
Board627's Avatar
Board627
Third brake light seal I would check. It has leaked on both of the f150s that I have owned.
Old Mar 30, 2006 | 10:48 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Yeah...mine leaks too. The origional owner said he had the rear glass re-sealed before, but its still leaking. Only if you hit it with a water hose though....it wont leak when it rains.
Old Mar 30, 2006 | 01:19 PM
projectSHO89's Avatar
projectSHO89
The rear slider has a seal that very commonly leaks.
To repair, the rear window has to come out.
I've got the procedure bookmarked on one of my other computers since I need to do this repair.
Steve
Old Mar 31, 2006 | 09:13 AM
skilife17's Avatar
skilife17
My rear slider leaks only when I go to a carwash, if it rains it doesn't leak.
Old Mar 31, 2006 | 10:08 AM
stang3O2's Avatar
stang3O2
Any heavy rain would soak my driver side rear seat in the ext-cab. Could never figure out if it was the light or window. I just went out and bought a tube or silicone sealant and neatly put the sealant all around the window and light...anywhere there was a seam that water could get through. Had this problem for over a year now and finally a month ago went this route and NO LEAKAGE as of yet!
Old Apr 5, 2006 | 11:20 PM
71100's Avatar
71100
my 6yr old sun told me he waz geting wet on the way home from school the other day when it was raining it is comeing in wright behind the pass seat in the rear so the silicone sounds like a good idea just do like stang did thx fte kicks ***
Old Apr 6, 2006 | 08:59 AM
bamadoc's Avatar
bamadoc
If you have the solid back window you can try resealing it. Mine was leaking and smelling moldy in the cab so I went to autozone and bought some sealing cord. Think it was like 10 bucks. Just pop the trim off the inside and carefully undo the nuts holding the window in. Scrape off the old leaking cord and put you new one down. Bolt the window back in and replace trim. Mine hasnt leaked in over a year and dont expect it to any time soon. Now if I could just fix that crappy idle when warm.-Bamadoc
Old Apr 6, 2006 | 12:58 PM
TEKWS01's Avatar
TEKWS01
If the slider is the problem, I believe ford has a service bulletin to repair...
Old Apr 6, 2006 | 10:47 PM
jfarm's Avatar
jfarm
same problem here, dont even waste your time sealing it yourself it does no good
Old Apr 7, 2006 | 04:33 PM
stang3O2's Avatar
stang3O2
What back window do you have JFARM? Seems like alot of us here sealed it ourselves, cost only about $10, and problem free...NO LEAKAGE! Seems to me a guy might try this first, worked for many of us!
