Sponsored by: Auxito
Speedometer Cable Squeaking????
Old Apr 6, 2006 | 07:40 PM
ow_hastings's Avatar
ow_hastings
I have an f150 99 4.2 and am having this horrible noise coming from right under my seat. I have lubed almost every crevise under my truck and the squeak is not weakining. It seems to be loudest when i press on the gas pedle and pick up speed. Please, any ides will help.
Old Apr 7, 2006 | 06:05 AM
ford390gashog's Avatar
ford390gashog
It can't be the speedo cable because your truck does not have one it only has a VSS on the rear diff no cable.
Old Apr 7, 2006 | 08:31 AM
Racerguy's Avatar
Racerguy
Welcome to the forum ow_hastings
It sounds to me like you might have a dry U-joint. I would remove the driveshaft and carefully check the U-joints for any looseness or binding or rough feeling.
Old Apr 7, 2006 | 01:41 PM
7700Rob's Avatar
7700Rob
I agree. Mark the drive shaft and the rearend before you take it out. Do the same with the yokes and shaft if you take that apart, other wise you may have a vibration when you're done.
Old Apr 7, 2006 | 05:54 PM
ow_hastings
thanks for advise. i will try and give update.
