351w missing after overhaul
Old Mar 27, 2006 | 07:28 PM
cowgriller's Avatar
cowgriller
Redone a 1982 f-150 351w everything new only thing not factory was the comp cam 35-216-3 first time i put it together it had a whine, took it back out found that an oil keepin ring bent, replaced all rings and rod bearing put back together, now, it sounds like its missing on 2 cyl. it has the screwed up dist. I think the cali. engine. What could possibly be wrong besides the firing order, i know i have that right.
Old Mar 28, 2006 | 09:02 AM
Kemicalburns's Avatar
Kemicalburns
need to match the firing order to the cam. what does plug 2 look like?
Old Mar 28, 2006 | 01:12 PM
cowgriller's Avatar
cowgriller
what is the firing order for this comp cam 35-216-3?
Old Mar 28, 2006 | 03:07 PM
Kemicalburns
did it not have one in the box? whats your timing set at? should be 10*btdc with vac advanc plugged
Old Mar 28, 2006 | 04:32 PM
cowgriller's Avatar
cowgriller
got the miss out of it, brand new dist cap had a small crack by #2, whole other problem now, have a slight whining almost a knocking noise, Could i have spun a bearing?
Old Mar 29, 2006 | 09:43 AM
Kemicalburns
whats your oil pressure look like. did you perform the cam break in?
Old Mar 31, 2006 | 01:39 PM
cowgriller's Avatar
cowgriller
Found the problem, i have about 1/16 of an inch end play in crank, got the right bearings, machinist screw up??
Old Mar 31, 2006 | 02:22 PM
booboo2073's Avatar
booboo2073
Bearings
You have a problem with your bearings, you might want to give me a call and i will tell you.
Old Apr 2, 2006 | 07:48 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Micbruff
23
Nov 5, 2014 08:17 PM
351Cleveland C4
The Next Generation
23
Sep 23, 2013 06:00 PM
Andrew Tuning
Jul 23, 2012 04:06 AM
Eric_F250
24
Mar 24, 2009 08:48 PM
Fuzzy
16
Mar 9, 2005 10:44 AM
