conversion parts 400/460
Old Mar 27, 2006 | 05:36 PM
79_250RangerLariat's Avatar
79_250RangerLariat
I was wondering where you guys have been getting your conversion parts? The truck is a 79 250 4x4. 400 is getting a pretty good knock..so I think it's 429/460 time. If it's cheaper than building a 400. Need good torque for towing.
I checked L&L but the $$$ keeps piling up. I know I'm going to need new motor mounts, and the bell housing spacer, and different headers. L&L is about the only place I've been able to find in chassis. Thanks!
Almost forgot..what year of 460 is the best to find? Someone told me 78 wasn't a good year.
Old Mar 28, 2006 | 10:15 AM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
20 years ago I did a swap on my 78 F250 4x4 351m/400 to a 429, I took the poor man route.I bought 65 ford 390 motor mounts drill one hole, use left for right and right for left, ablong the trans mount support brkt, made new drive shaft, made a new alt brkt, and ablonged the ps pump brkt and it worked like a charm. but there are some companys out there that make a conversion kit that does it all. I use a 429 out of a 72 merc, 10 to 1 comp. It bolted right up to the C6.
Ed
Old Mar 28, 2006 | 11:26 AM
RedStroke's Avatar
RedStroke
I have used L&L in the past most of there products are good but pricey. Broke two sets of there first motor mounts though, but they are warrantied.
Old Mar 29, 2006 | 08:40 PM
junkyardjeff's Avatar
junkyardjeff
The 400 has the same bellhousing bolt pattern as the 429/460 so you will not need to change trans,motor mounts and exhaust will be the only big parts to change. Jeff
Old Mar 30, 2006 | 05:32 AM
79_250RangerLariat
Even though the 429/460 bell is the same as the 351m/400 I thought the 460 housing was 1/2" or so shallower than the 400?
Old Mar 30, 2006 | 06:55 AM
RedStroke's Avatar
RedStroke
If you use a auto you dont have to change anything, a stick needs a somewhat special flywheel
Old Mar 30, 2006 | 01:13 PM
Thomsen's Avatar
Thomsen
The manual does not need a special flywheel, you just need to shim the bellhousing if using a 351/400 bellhousing. The 460 housing is about 3/8'' deeper than the M bellhousing. I built a 5/16'' shim out of plate and used the stock 1/8'' dust shield to create the needed 3/8'' total shim for my 460 swap using a 400 bellhousing.
Old Mar 30, 2006 | 04:47 PM
79_250RangerLariat
Ok, starting to get a bit confused. As long as I stick with my C6 automatic I can bolt a 429 or 460 up without using the spacer plate to make up the 3/8 inch.
So all I would really need is a set of motor mounts, headers, and acc brackets?
Old Mar 31, 2006 | 11:27 AM
460man's Avatar
460man
shim
how did you or how do you make the shims. what if you used washers or something. anyideas
Old Mar 31, 2006 | 11:35 AM
seventyseven250's Avatar
seventyseven250
And if you feel like doing some work on the 400, check out the 335 sereis engine forum. There's a lot of potential in that engine.
https://www.ford-trucks.com/forums/f...splay.php?f=54
Old Apr 4, 2006 | 11:27 AM
Thomsen's Avatar
Thomsen
You could use washers but then you have an open gap between the bellhousing and engine. Not to mention it would not be very stable . When I built my plate i used extended engine dowels and the plate goes over them, which made it very stable.
Old May 30, 2006 | 12:40 AM
darrin1999's Avatar
darrin1999
some info
your 400 and 460 share the bell housing... all you need for an auto swap is the 460, 460 torque converter and flywheel, motor mounts, and exhaust... and if the motor is out of a car youll need a rear sump oil pan kit for the 460... also the car manifolds dont fit on the right side
Old Jun 7, 2006 | 02:02 AM
justine's77ford's Avatar
justine's77ford
Looks like i learned the hard way. when i swapped from 400 to 460, i kept the 400's converter. i did have the 460 flywheel though. is their a reason for having the 460 converter too.
What about the 400's starter. will that work in the 460? Is there any shims needed?
Old Jun 9, 2006 | 03:43 AM
darrin1999's Avatar
darrin1999
starter will work
the 400 starter will work no problem... you could use the 400 torque converter if you dont mind about a half inch between the bellhousing and the engine... the 460 output shaft is a little longer so you need the 460 converter
Old Jun 9, 2006 | 03:50 AM
darrin1999's Avatar
darrin1999
one more thing
in your original post you asked for what years to avoid... the only bad year was 1972... d2ve heads are garbage... and after 88 they went to fuel injected heads and they wont work with a carb manifold... otherwise anything else from 1968-1987 will work fine... 68-71 engines are high compression so watch what gas you use if you come across one (c8ve to d0ve castings)
