1984 ford truck engine options.
Old Mar 27, 2006 | 01:52 PM
bigdaddysatan's Avatar
bigdaddysatan
what engines came standard in the 84 ford truck lines. light truck
Old Mar 27, 2006 | 02:10 PM
pfogle's Avatar
pfogle
F150 would have had: 300 (4.9l)I6, 302 (5.0l) V8, 351w (5.8l) V8
F250 would have had all of the above and also a 460 (7.5l) V8
F350 would have had all of the above and possibly the 6.9 diesel, I forget what year it was introduced. Also I don't think the 302 was offered in a F350.
Old Mar 27, 2006 | 03:04 PM
bigdaddysatan
ok
no big blocks in the halftons much eh?
Old Mar 27, 2006 | 04:41 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome bigdaddy to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 27, 2006 | 06:11 PM
pfogle's Avatar
pfogle
No, not from the factory. If you wanted to swap one in, it wouldn't really be difficult. You'd need a heavier set of springs (or coil over shocks) for the front, and the big block frame mounts, and the big block transmission. If it's a manual you can get by with a bellhousing change (if it's removable), if it's an auto most of those are fixed bellhousings so you'd need the entire transmission.
Old Mar 27, 2006 | 07:16 PM
srercrcr's Avatar
srercrcr
When you sat "standard" I presume you mean with no extra cost. That would be the 300 then.
Old Mar 27, 2006 | 07:19 PM
dave74-360bb's Avatar
dave74-360bb
the 6.9 diesel was also offered in the f250
Old Mar 27, 2006 | 09:28 PM
bigdaddysatan
thanks. guys
Old Mar 28, 2006 | 07:29 PM
bigbrown84truck's Avatar
bigbrown84truck
the 302 was not available in an f-250; however the 300 inline six was available in a f-250. the biggest motor in an f-150 in 84 was the 351, once you got to the f-250 then you could get the big motors. also don't forget the 300 was available in an LP gas version.
edtahaney
General Automotive Discussion
Aug 5, 2014 05:09 PM
jimbbski
General Diesel Discussion
Feb 9, 2010 09:57 AM
wagonwrench
Sep 23, 2008 01:33 PM
ps91368
Sep 11, 2006 12:43 AM
canzus
Aug 27, 2002 08:40 AM
