oil pan seal replacement
Old Mar 27, 2006 | 01:42 PM
helpfulguy's Avatar
helpfulguy
I am going to change the oil pan seal this week. i have already purchased the stuff from the ford house for this job. My question is, is this as straight forward as it seems or is there something else i need to be aware of?
Old Mar 27, 2006 | 02:43 PM
ltfox's Avatar
ltfox
Your pulling the engine right?? It nearly impossible without pulling the motor.
Old Mar 27, 2006 | 03:07 PM
helpfulguy's Avatar
helpfulguy
no, i was not planning on it. i am going to drive it over a truck oil pit and try it removing it from there.
why is it nearly impossible?
Old Mar 27, 2006 | 04:46 PM
96P_Stroke4x4's Avatar
96P_Stroke4x4
Smokin'
the front crossmember does not give enough clearance to allow the removal of the pan.
Old Mar 27, 2006 | 05:13 PM
94_turbo's Avatar
94_turbo
helpful--wash all around the pan seal area--real good--then with alcohol or paint thinner---clean well--then put a small amount of atv all around the pan seal area--smooth with fingers if necessary---people that have tried this said it stopped the leaks---use only the ford gray pan seal trv-its totally diff than anything else you buy--
Old Mar 27, 2006 | 05:18 PM
helpfulguy's Avatar
helpfulguy
thanks i just might try that, i will still drive it over the pit and then when i can get to it real good i will decide which way to go. And i did buy the stuff from ford figuring it was not an over the counter sealant.
Old Mar 27, 2006 | 05:23 PM
79_250RangerLariat's Avatar
79_250RangerLariat
is your truck 2wd or 4wd? I had to have Ford change the pan on my 97 4wd about a month ago. Came to the tune of $1400, while it was out they changed the rear main. I like to do all my own mechanic work, but when ford figured 15 hrs, and I don't have concrete to work off of.....
Old Mar 27, 2006 | 08:43 PM
1997F-350's Avatar
1997F-350
if you got the wacker/ t442 sealer you are good this stuff is strong.
Old Mar 28, 2006 | 08:26 AM
helpfulguy's Avatar
helpfulguy
i hear ya on the no concrete part. don't have any at my house either, but i am lucky that i have a friend who has a truck shop with everything i would need. used his shop last month when i changed the flywheel in the same truck.
krvoorheis
2015 - 2020 F150
110
Aug 17, 2022 04:01 PM
tiim5
Mar 7, 2017 11:51 PM
robjs111
1997 - 2003 F150
Apr 1, 2011 08:19 PM
mikev
Nov 12, 2010 02:01 PM
02GrayPowerStroke
30
Jul 30, 2008 11:37 AM
