PS Pump Whine
Old Apr 5, 2006 | 03:12 PM
pawpaw's Avatar
pawpaw
Jas88 from your description of the old fluids condition, it sounds as if it looked like my 94 Taurus P/S fluid did, pretty beat up. lol
If the "roughness" isn't cured by the detergent/dispersants in the new fluid, you might consider trying half a can of SeaFoam Trans Tune.
It straghtened out a P/S shudder in my 99 Ranger last fall, after a 40 mile round trip. P/S fluid still looked/s good, bright red & clear, but there must have been some deposits, maybe a little varnish, or sludge, that it's put into suspencion, but not enough to discolor the fluid.
Anyway it'll all come out soon & we'll see how it does without any TransTune.
I don't normally use any kind of additives in my fluids, unless they are specfied by the mfgr, but I've had good luck on the Taurus & Ranger P/S, with brief, limited use of the TransTune.
I'm due for a P/S & Tranny fluid change this spring, so I left the 1/2 can of Trans Tune in there over the winter & will add the other half a few hundred miles before my upcomming spring flush.
Just some thoughts for consideration.
Old Apr 7, 2006 | 08:33 PM
woolie74's Avatar
woolie74
Originally Posted by texan2004
I will try this. It makes sense and my attempts at bleeding were done with the engine running and thus the PS pump turning.
BTW - Why is it that you haven't had to replace a PS pump on a Ford but you have on Chevy's? Just curious.
Sorry for the late reply, I just read your post. I am a ford man but I happen to be a mechanic in a chevy shop.
Old Apr 8, 2006 | 08:21 AM
texan2004's Avatar
texan2004
Tht's OK. If I reparied vehicles for a living, I would probably choose to work at a Chevy (or better yet Chrysler/Mopar) shop. You go where the work is and we all know Chevy's are more prone to needing repair than Ford's. Right??
Old Apr 9, 2006 | 05:36 PM
woolie74's Avatar
woolie74
Yeah, If it weren't for GM, I would probably starve.
SouthpawMason
16
Nov 18, 2009 03:40 AM
navistar2000
25
Oct 14, 2007 02:41 PM
CE-f250
Feb 9, 2007 11:25 PM
reamer
Sep 24, 2004 02:08 PM
woodman209
Jul 6, 2004 02:52 AM
