How often should bearings be repacked?
Old Mar 27, 2006 | 10:49 AM
sportscar's Avatar
sportscar
Got an open car trailer with 4 years and 8,000ish miles. I have had to take up some slack on the bearings. Sounds like time to do it?
Old Mar 27, 2006 | 06:50 PM
ksuroper's Avatar
ksuroper
Pull the hub off, take out the bearings, clean them to remove all the old grease(gasoline works great), then inspect all of the rollers to look for rust/wear. If they are ok, repack them with new grease and reinstall.
Old Mar 27, 2006 | 09:19 PM
Wagion's Avatar
Wagion
bearings are not that expensive just replace them and be safe better than getting a tire seize on tthe road somewhere get bearing buddies and put on the trailer carry a grease gun with you or in a tool box on the trailer and regrease them every time you change the oil in your truck grease is cheap and if they are alwaays greased they will last for ever
Old Mar 27, 2006 | 10:28 PM
seetwisted's Avatar
seetwisted
If they are full of grease, water and dirt can't get in. If you tend to overload or leave it sit for long periods of time,grease or re-greaseing is cheap insurance.Bearing buddy's are nice but I've seen them get jammed with old grease and not feed the grease in.Then a wrongly confident owner drags the trailer around until he notices something wrong. And I like whatever grease I can find with the highest "drop point" available.Of course I still haven't said how "often",But if you check anything often enough you get familiar with wants and needs.
Old Mar 28, 2006 | 10:46 AM
Toyman's Avatar
Toyman
As a rule of thumb, in the RV industry, it is best to remove and inspect the bearings at least once a year. Always clean and repack when reassembling, with new seals. The biggest problem with the bearing buddies is that you never get the old broken down, overheated grease out. Now in your situation, you are only using the car a few times a year. I would get in a habbit of inspecting and cleaning the bearings every other year, when you pull the hubs off to pack the bearings, you can also visually inspect the brakes and make any adjustment necessary here. It takes a little while to get everything clean and reinstalled, but a little preventive maintainance time is better than sitting on the side of the highway thinking about how much it will cost to replace the axle due to a siezed bearing.
Don't get me wrong bearing buddies are great for trailers with the little donut tires (I use them also), but those tires spin twice as fast as full size tires. This creates more heat. I still repack my snowmobile trailer bearings every year. After the first trip I squeeze some grease in the bearing buddies for the next trip.
Toyman
Old Mar 29, 2006 | 10:09 PM
jtexas's Avatar
jtexas
Also inspect the races - any discoloration, replace 'em. Never use a new bearing with an old race - change both or neither. Never reuse a rear seal. Inspect the spindle - any discoloration needs to be removed with emory cloth. Don't overfill bearing buddies - pump grease in until it just starts to move - overfilling can blow out the rear seal.
Old Mar 30, 2006 | 01:57 AM
V10man's Avatar
V10man
Don't use gas!! Use paint thinner or other solvent.
Old Mar 30, 2006 | 05:02 AM
sportscar's Avatar
sportscar
Thanks Guys, I replaced the bearings. Grease was thinned out a bit, but the bearings all looked good. I got new seals from the local trailer shop. Much easier than I anticipated.
swampfire79
Sep 26, 2012 10:13 PM
TD2000Merc
Apr 9, 2007 09:29 PM
huntingnt
Mar 16, 2007 05:32 PM
Ironbelly
S. California Chapter
26
Nov 6, 2003 10:22 AM
karlsd
May 30, 2002 12:14 PM
