Sponsored by: Auxito
LS Install
Old Mar 26, 2006 | 09:43 PM
zman764's Avatar
zman764
LS Install
Ok I have posted a couple of different times about my open differential on my 97 4x4 4.6. But I think I found what I want now.
http://store.summitracing.com/defaul....asp&x=13&y=10
This appears to be a factory ford LS unit made to go into my factory 8.8 open differential. How hard of a job is it for a mechanically inclined person with 0 experience with differentials to do this? How reliable are these units? 239 bucks seems pretty good what do ya'll think?
Oh yeah part number FMS-M-4204-F318 it should be the top one on the list. The 239 dollar one.
Thanks
Old Mar 26, 2006 | 10:00 PM
LxMan1's Avatar
LxMan1
That is the one that came factory. It is a pretty good unit. The one in my Mustang (28 spline) Still smokes both tires after 160,000 miles. You must know how to properly set the backlash of the gears and must install a new crush sleeve on the pinion. I would go ahead and replace the bearings while it's apart just to be safe.
You may try to find a book on differentials before tearing into it.
Old Mar 26, 2006 | 10:02 PM
zman764's Avatar
zman764
Also the same unit in your 01 right? Hows it do in the mud? Hmmm. sounds like I need to have it installed professionaly though ha ha.
Old Mar 27, 2006 | 07:34 AM
preppypyro's Avatar
preppypyro
That does sound like there is alot to it. Might be easier to go get a good used one from a wrecker!
Old Mar 27, 2006 | 08:52 PM
zman764's Avatar
zman764
Thats another question.. how hard would it be to instlal an entire new rearend from another truck?
Old Mar 27, 2006 | 09:09 PM
preppypyro's Avatar
preppypyro
To install a whole rear end would be simple. Unbolt a few bolts here and there and voila! lol
Old Mar 27, 2006 | 09:21 PM
tchernosky's Avatar
tchernosky
I don't know if it would be easy, you would probably need a second set of hands and a couple jacks and jack stands, but would most definitly be easier than tearing into the inner workings of the rear end. Let us know how it goes. I was curious about doing this myself, but became a little overwhelmed with all the elements involved
Old Mar 27, 2006 | 09:36 PM
zman764's Avatar
zman764
Other than the u bolts what all is involved? Do u joins come apart easily/at all? Or is there another way of removin the pumpkin from the drive shaft?
Old Mar 27, 2006 | 10:02 PM
preppypyro's Avatar
preppypyro
You can unblot the driveshaft from the pumpkin, 12 metric wrench is it? I think thats what your talking about right?
Old Mar 27, 2006 | 10:46 PM
zman764's Avatar
zman764
Well its just 1 bolt or what?
Old Mar 27, 2006 | 10:49 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Should be 4 of 'em....
Old Mar 27, 2006 | 10:53 PM
zman764's Avatar
zman764
do they come out easy or is there abunch of unforseen consequences in taking them out?
would it just be a matter of 4 bolts on the ujoins, the ubolts, unplugging w/e sensors there are and hookin up the new one the same way this came out?
Old Mar 27, 2006 | 10:57 PM
apowder97's Avatar
apowder97
Did your truck not come factory with a LS rearend? my 97 F150 did
Old Mar 28, 2006 | 07:14 AM
preppypyro's Avatar
preppypyro
Mine didnt, it came with the open rear end
Old Mar 28, 2006 | 07:42 AM
Forddieselweasel's Avatar
Forddieselweasel
hmmm little off topic but will changing the fluid with some of the LS additive help reguvinate my LS. if the wheels turned left itlle smoke both and slide around, but if i turn right itll only spin one unless its wet. can i gain a little bit of the ps back by changing the fluid? thanks
50,000 miles
