1956 223 engine wiring
Old Mar 26, 2006 | 07:49 PM
fleetline46's Avatar
fleetline46
Need a little help with a wiring question...on a 1956 6 cylinder 223
Does the wire from the starter solenoid go to the resisitor terminal that is close to the block??? and then does a small wire go from the front terminal to the positive side of the coil. After that does another wire go from the negative terminal on the coil to the botton of the distributer. I know the book says that there will be hotter spark upon trying to start and then after the motor is running it will be cut down..If not working properly the points will burn up quickly...I do not understand how this works. Do I have it wired properly????
Thanks
Old Mar 26, 2006 | 08:08 PM
Randy Jack's Avatar
Randy Jack
I believe you're description is missing a wire from the ignition switch to the engine side of the ballast resistor. The wire from the solenoid is only powered when starting. The ignition switch wire provides power while running. The distributor points will be OK for the short start duration.
Old Mar 26, 2006 | 08:26 PM
fleetline46
Randy
there are 2 terminals on the starter solenoid...The wire I am referring to coming from the solenoid is attached to the terminal marked (I) which I think stands for ingnition going to the terminal on the resistor closest to the engine.
Correct???
Thanks
Old Mar 26, 2006 | 09:04 PM
Randy Jack's Avatar
Randy Jack
I'm looking in my Shop Manual (page 73) and see a picture (Fig 1) showing the ballast resistor and coil. It shows the (+) pole of the coil having two wires connected to it. One comes from the ballast resistor and the other comes from the "I" terminal of the starter relay. The (-) coil terminal is connected to the distributor. The other wire on the ballast resistor goes to the "coil" terminal of the ignition switch. If your wiring is still stock, maybe that will help.
Motorhaven (or ebay) carries Shop Manuals. Buy one. You'll be glad you did.
Old Mar 26, 2006 | 09:12 PM
fatfords's Avatar
fatfords
Fleetline,
RJ is right on the shop manual. If you "need it now", I think George has the wiring diagram for a '56 on Earl's World, under the "technical" section.
Good Luck!
Old Mar 26, 2006 | 09:56 PM
fleetline46
Than ks for all of the info...I have a shop manual and also an old motors repair manual but nothing shows in detail....When I purchased the truck a few years ago it was disassembled and sometimes I get stuck on some issues
It is really good to have guys like you out there to help
Thanks again
wmkmun
Aug 17, 2016 08:39 AM
rpaxton939
Jan 10, 2014 11:56 PM
desi778
May 29, 2012 07:24 PM
hivolt5.0
Jun 22, 2011 08:17 PM
