Aerostar Ford Aerostar
Pip
Old Oct 21, 2003 | 01:24 PM
chucknc's Avatar
chucknc
Pip
Actron diagnosis indicates intermittent loss of PIP
(Profile Ignition Pick up). What does this mean and what should I look for to fix?
Old Oct 21, 2003 | 02:05 PM
AeroRat's Avatar
AeroRat
Lightbulb
Sounds similar to:
http://69.61.23.2/forums/showthread....hreadid=142864
Check for my first post (Aerorat) on this thread...
Old Oct 21, 2003 | 04:14 PM
chucknc's Avatar
chucknc
Thanks for the advice. Checked thread and found good ideas but to no avail. The green wire you mentioned seems to be in good shape, I even replaced ignition coil (cheap, easy). Where does the green wire go? Also, you mentioned a wire near the master cylinder. Would this be the one that goes to the (-) terminal?
Old Oct 21, 2003 | 05:44 PM
aerocolorado's Avatar
aerocolorado
PIP is also known as the Hall-Effect sensor, a magnetic inductance sensor in the distributor. Instead of the distributor sending a spark via the rotor, the rotor trips a magnetic sensor which in turn fires the coil at the appropriate time. Your error may be a loose wire, poor ground or just bad sensor.
Here's a good link for additional reading:
http://www.wellsmfgcorp.com/counterp...erpoint3_1.pdf
Old Oct 21, 2003 | 08:32 PM
chucknc's Avatar
chucknc
3.0 makes chasing wires quite challenging. Having done that, with all connections seeming intact,does a bad sensor mean replace distributor?
genotac-f250
6.4L Power Stroke Diesel
Feb 20, 2016 02:22 PM
stevenjf88
May 31, 2015 10:44 AM
mdula
Jun 20, 2011 02:04 PM
jemini
Nov 21, 2007 04:17 PM
b4hntn
1978 - 1996 Big Bronco
Nov 3, 2006 11:20 PM
