400 upgrade advice needed
Old Apr 1, 2006 | 02:04 PM
  #31
tastyklair's Avatar
tastyklair
Wait clark351. Don't say the lines are drawn yet. I'm not finished...blah blah blah
Old Apr 1, 2006 | 03:27 PM
  #32
Bdox's Avatar
Bdox
I wonder if Ferrite got his questions answered?
Old Apr 1, 2006 | 05:27 PM
  #33
baddad457's Avatar
baddad457
Originally Posted by 1972FordCustom
here he says that he has never replaced a power valve and he dont know anyone that has, but in his last reply, he was talking about buying a holley and having to replace the power vavle...ummmmmmm interesting...
As grclark pointed out already, the rubber diaphram in the powervalve hardens after sitting too long and must be changed to have any hope of the carb functioning properly. This is the only reason I've ever had to change one, other than changing one due to it's being the wrong one for the application. I've also had more than my share of backfires and never had one blowout from it. I don't know where that rumor started, but it sure as hell wasn't from me.
Old Apr 2, 2006 | 10:04 AM
  #34
BroncoChuck's Avatar
BroncoChuck
I would like to throw my two cents worth in here. I had a Holley under the hood of my Bronco for 3 years, and positively hated it. It ran PERFECTLY on flat, level ground. Huge power, fun to plant the heavy foot, etc. The problem came on severe hills and angles. Fuel spillover was a huge problem and my truck wouldn't run. More than once I had to roll down a rough stretch of trail backwards without power to get it level and running again. I went back to the motorcraft 2bbl for that reason. The only Holley I would ever put back in would be the truck avenger.
As for tuning problems or blown power valves I never had a single problem.
Old Apr 2, 2006 | 10:41 AM
  #35
tastyklair's Avatar
tastyklair
Before the days of the Avenger series Holley had a vent baffle add on that you could use to help stop fuel from sloshing out. It was intended for racers with either hard cornering as in roundy round guys, and severe accelleration as in the drags. Probably would have helped sideways trucks as well but that wasn't the intention back then.
Old Apr 2, 2006 | 10:56 AM
  #36
baddad457's Avatar
baddad457
They have jet extensions as well to prevent fuel starvation in the primary side on severe downhill grades too.
Old Apr 2, 2006 | 02:37 PM
  #37
Torque1st's Avatar
Torque1st
Posting Legend
This discussion would be best in the carb forum but...
Both the Motorcraft and the Holley carbs were subject to power valve blowouts. Even a brand new power valve could be blown from a single backfire. I have personally experienced this dozens of times. It was a major pain to be tuning an engine and get a backfire then having to replace that $@$*#! power valve. That is the reason Holley introduced their check valve to prevent most (not all) blowouts. I made major amounts of cash at one time tuning carbs (and replacing power valves) for people, both Holley and Carter/Edelbrock. Both systems have their faults and strong points. For any kind of weekend performance or racing application I prefer to use Holley carbs because of their adaptability and accessories, but for a daily driver I prefer to use an Edelbrock. I have owned many types of carbs and I have worked on even more.
Old Apr 4, 2006 | 12:38 PM
  #38
BroncoChuck
I know this may cause even more controversy but, The BEST working off-road carb I have seen on the trails is the quadrajet. As much as it hurts me to say it, it runs smoothly on any angle, even when the blazer in question was laying on its side.
FordFETruck
17
Nov 24, 2012 03:22 PM
Myfreeford
Dec 5, 2011 02:34 PM
OVERBOOST
Jun 6, 2005 03:06 PM
AK429
Jun 5, 2004 08:15 PM
IlllMikeIlll
May 6, 2002 02:25 PM
