upgrade
Old Mar 26, 2006 | 01:24 AM
dorsetmerv's Avatar
dorsetmerv
upgrade
How much will it cost if i get a garage to upgrade my rear 3.55 axel on my f250 to a 4.1 to increase my towing capacity?
many thanks guys.
Old Mar 26, 2006 | 04:12 AM
12V's Avatar
12V
assuming 2WD, probably in the five hundred dollar range, if you provide the parts.
You probably already know this but if it is 4WD DO BOTH OF THEM!!!!!
sorry, i had to say it.
Old Mar 26, 2006 | 05:05 AM
shorthair's Avatar
shorthair
not sure why you'de want to swap I have 3.55's & tow a 31' 8000# + TT on a regular basis. just drop down to 4th as soon as her nose goes up & I get the same gearing as if I had 4.10s & still get the mileage benifit of the taller gears when mt which happens to be a lot more than not.
Old Mar 26, 2006 | 11:21 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
many thanks guys.
Around here...$900-1200 per axle. Parts and labor.
Old Mar 26, 2006 | 01:33 PM
Dave Sponaugle's Avatar
Dave Sponaugle
You don't want to know how much I tow with 3.55's and 33" tires on a regular basis, but it is over 20,000 gross here in the mountains with a 4 speed manual.
The only thing that would benifit from lower axle ratios is the U joint and driveshaft life.
With fuel prices I can afford to replace them rather often since I still get reasonable MPG's when running empty.
After looking at the numbers I guess it would not be that bad with a ZF 5 to go to 4.10's, 2400 would be 70 MPH with 31" tires. Still your MPG's will take a hit if you do much freeway driving.
Old Mar 26, 2006 | 04:13 PM
jboard's Avatar
jboard
Dave what is your mpgs with 3.55s empty?
Jeremy
Old Mar 26, 2006 | 04:51 PM
Dave Sponaugle
At 70 MPH I am getting about 13 MPG.
Old Mar 26, 2006 | 06:39 PM
jboard's Avatar
jboard
How much higher would that be i you had a ZF 5 speed? I would think a good bit higher.
Jeremy
Old Mar 26, 2006 | 08:05 PM
Dave Sponaugle
Well since I was averaging 10 before the IP swap last weekend I am happy again.
33" tires and a T19 with 3.55's = 2650 RPM at 70 MPH
I don't think a ZF 5 could stand what I do with my truck for very long.
I would like to drop the RPM at highway speeds, but I like my indestructable cast iron transmission.
I am holding out for a ZF 6 after I can rework the dash and rear axle swap so I can have a speedo.
Old Mar 26, 2006 | 08:13 PM
jboard's Avatar
jboard
Sounds good to me
Jeremy
bpete
Jul 29, 2013 11:06 AM
lilpro
Apr 24, 2013 08:53 PM
ItsAFord55
Dec 13, 2011 01:18 PM
hfugate
Nov 24, 2009 12:04 PM
abnjumpmaster
Mar 3, 2008 02:30 AM
