I have a 2001 Ford Ranger XLT extended cab 4.0L SOHC 5 speed manual with 50,000 miles.
I've had the truck for just over a month, when the engine started missing on wet roads at cruising speed. It is perfectly fine with no missing on dry pavement, only when wet.
I have replaced the air filter, spark plugs and spark plug wires and it is a small amount better, but I continue to have a miss only during wet conditions. The check engine light does not go on, and the scanner does not register any codes.
I have looked at the EDIS/coil, and have measured the secondary resistance with a result of an average reading of 12,500 ohms. The Haynes manual states normal specs for secondary resistance as 13-15 K-ohms. So, I went to checker auto parts and tested one of there brand new ones and the average reading was 11,200 ohms for the secondary resistance. Is my coil bad/faulty? Is checkers? I did not buy it as I still want a definite answer before I spend money on something that I may not need. Is the manual correct, or are there different parameters that I should be looking at? Where are they as I have tried calling dealers for the specs and they cannot give me an answer and I cannot find anything on the web for a 2001. Any other ideas that may be causing this engine miss in wet conditions? Don't have a clue where to go from here. HELP
*Perform visual on coilpack looking for any evidence of a hairline crack.
*Perform visual on low voltage connector on coilpack. Look for evidence of water intrusion as well as corroded connections. A small amount of silicon grease is good to apply to the bellows on the connector to discourage water intrusion. Ditto for a small dab of silicon grease on the boots of the spark plug wires prior to installation (makes for easier removal in the future too).
*Perform visual on the crank position sensor for a hairline crack.
*Perform visual on the crank position sensor connector. Use the same idea as noted above for the coilpack.
**You might try to replicate the problem by using a spray bottle filled with water and squirting the suspect component.
I don't have a problem when it is dry snow-no humidity. It is the wet snow and rain conditions that create the engine mis. Where are the typical "grounds" that seem to be the problem areas? I have checked all that I can see and get to. I have also tried spraying carb cleaner all over and around the intake manifold gasket surfaces. No hesitations or missing at idle when I do this. So where do I go from here?
