Newbie with a 95 f150 stalling problem
Old Mar 25, 2006 | 09:20 PM
Wheel_man4020's Avatar
Wheel_man4020
Question Newbie with a 95 f150 stalling problem
hello,
my problem is i have a 95 ford f150 with a 4.9 liter inline 6 and for some reason unknown to to me it stalls when rolling backwards with the clutch pushed in. i have changed the fuel filter fuel pump and fuel tank, also plugs, wires cap and rotor egr valve have had the tps, ignition module, and map sensor tested at the zone and they tested good. any help you can offer me would be greatly appreciated.
thanks
Old Mar 26, 2006 | 05:30 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 26, 2006 | 06:54 AM
water 5's Avatar
water 5
is this a cold start up or a warm truck does it idle rough?
Old Mar 26, 2006 | 10:13 AM
Wheel_man4020
does not matter if it is warm or cold does not idle rough runs good if you can get it backed out of driveway and movin down the road. also if it helps the speedometer bounces around alot can very like 10 to 20 mph will cruising at a constant speed i have no idea what it is
thanks for any help you can give
cowboy19
2004 - 2008 F150
Jan 23, 2013 04:54 AM
Ebrazil
19
Apr 28, 2008 11:07 PM
78F150XLT
15
Apr 24, 2008 12:38 AM
whiteaddiction
Mar 6, 2007 05:43 PM
LEESHIPPET
Sep 25, 2006 09:20 AM
