Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Chain saw not cutting
Old Mar 25, 2006 | 01:44 PM
Avanti's Avatar
Avanti
I have been using a gas chain saw for years. Put on a new saw chain & cut 10 chunks of oak. Than it acted like it was dull. Put on a sharpened old chain & same thing. I put on another used bar but no change. Cleaned everything. Clutch seems to work ok. I know the chain is not on backwards because of the book & comparison with an electric chain I also have. Runs great but no bite. Any ideas???
Old Mar 25, 2006 | 01:49 PM
helifixer's Avatar
helifixer
have a saw shop cut the rake down a little, that will give you a deeper bite "only if your saw has enough power to pull it"
Old Mar 25, 2006 | 10:43 PM
rebocardo's Avatar
rebocardo
If you went into the same kerf/cut where it started to act dull, then it is possible you hit something in the wood. I have cut cables, concrete, nails, what I think were lead cannon *****, pulleys, etc.
Now, you could have hit something with the new chain and the old chains just need the rakers taken down. If a chain is not too much money, then put it on and cut on a different piece of wood.
If the chain is just stopping, then maybe the engine is blown. Lift the saw up and hold it by just the cord handle, it should stay up or drop slowly if the compression is good.
Old Mar 26, 2006 | 12:14 PM
IrishEKU's Avatar
IrishEKU
Rebocardo is correct about the rakers if they are too high you won't get a cut at all.
Old Mar 26, 2006 | 01:13 PM
chrono4's Avatar
chrono4
whats a raker?
Old Mar 26, 2006 | 01:27 PM
helifixer's Avatar
helifixer
Originally Posted by chrono4
whats a raker?
The rake is what sticks up between the saw teeth, it acts like a depth gauge for the cutting teeth
Old Mar 26, 2006 | 01:28 PM
chrono4's Avatar
chrono4
oh ok, thanks.
Old Mar 27, 2006 | 09:30 AM
cokeman's Avatar
cokeman
Active Streak: 30 Days
Active Streak: 60 Days
How far do you guys take the rakers down? One of my brothers-in-law says he takes his all the way off.
Old Mar 27, 2006 | 06:07 PM
Defective's Avatar
Defective
Please ignore your brother-in-law.
Without the depth guages (rakers), your chain will be far too aggressive. This will make the saw very difficult to control and dangerous. It will also wear out your saw much quicker.
Best advice you will get is to go pick up a set of filing guides. The guides will help you to control the depth and get the angle on the teeth consistant.
Depth Guide
Angle Guide
Fancy (overkill) Guide
Old Mar 27, 2006 | 06:28 PM
chrono4's Avatar
chrono4
all the links took me to the same site.
Old Mar 27, 2006 | 06:47 PM
IrishEKU's Avatar
IrishEKU
Depth Guide
Angle Guide
Good points though the links bore the same results.
Rakers set the depth of cut on a chain. Too high, no cut, too low more cut. Most aquainted with saw's and chain's file the teeth and the rakers the same, every time to keep them even. I did plenty of time on both sides of the chain when I was in HS, I earned money cutting wood and clamming when I was on suspention for this or that. LOL, I earned more money while I was suspended than I ever did in class and busting my butt while in class.
Hope this helps!
PK
Old Mar 27, 2006 | 09:33 PM
Defective's Avatar
Defective
Hhhmmm...
Probably the redirector...maybe cookies...annoying...
Looking for product numbers:
Depth Guide = 54-5621-4
Angle Guide = 54-5647-4
Fancy (overkill) Guide = 54-5624-8
Could probably just find better links, but I'm too lazy...
Old Mar 27, 2006 | 10:56 PM
jake00's Avatar
jake00
your bar is well lubed right?
Old Mar 29, 2006 | 07:27 AM
rebocardo's Avatar
rebocardo
Rakers for most chains should be .025 - .030 below the lead cutting edge, too much and the chain will not cut. There are some exceptions, but, for most saws this is a good rule of thumb. Without rakers your chain will not cut at all because the rakers do just that, they rake the wood and break the fibers so the chisel part on the chain can lift the chip.
Some chain (mostly full comp safety chain - 91V and 72v) is not suppose to have the rakers filed down at all.
What you can do is take an old chain, give every raker a quick two swipes with a flat file and see if the chain cuts better on a side by side cut. If it starts throwing out big square chips then it is spot on.
Old Mar 29, 2006 | 05:09 PM
Defective's Avatar
Defective
I really don't intend to sound insulting...but...
This statement is 100% wrong.
The only thing the "rakers" do is control the depth each tooth can cut into the wood. The depth guages (rakers) have no edge to cut with. If your saw chain is "breaking" the wood, it's dull.
