waaay high RPM's.........
Old Mar 24, 2006 | 09:10 PM
Stuckinmud's Avatar
Stuckinmud
Was driving my 85 full size bronco when i thought the gas pedal was stuck, turns out the motor wont rev below 3000 rpms. Its a 351w with a four barrel. Im thinking it could it be a vacum leak or carb problem. I did find a hose that was loose and when pluged it dropped rpms a little but not enough. Its currently sitting on the side of the raod and i wanna see if i can diagnose it myself before i get it towed somewhere.
Any help appreciated.
Old Mar 24, 2006 | 09:21 PM
amish77's Avatar
amish77
a buddy of mine had this problem with his impala, he rebuilt the carb and it dropped back. It may be a choke problem, or another vacuum leak. I'd get some starter fluid, spray around the vacuum lines and intake and see if there's a leak. You may be able to limp it back home if you keep it in the lower gears.
Old Mar 24, 2006 | 09:31 PM
Stuckinmud's Avatar
Stuckinmud
Thanks for the reply, the vacum lines are a mess there are lines un hooked some are plugged with screws. Pretty scary really....i may just have to suck it up and take it somewhere. Driving it like it is, is hard on the brakes.
Old Mar 24, 2006 | 09:41 PM
Neb86's Avatar
Neb86
Make sure your carburetor secondaries are closed.
Old Mar 24, 2006 | 09:55 PM
frdnut's Avatar
frdnut
Yep that's what I was going to say.
Old Mar 24, 2006 | 10:56 PM
Stuckinmud's Avatar
Stuckinmud
CArb secondaries? What are those? I know squat about carburators.
Old Mar 24, 2006 | 11:23 PM
Stuckinmud's Avatar
Stuckinmud
Ok did some reading on carbs, ill check out the secondaries tommorow.
Old Mar 24, 2006 | 11:57 PM
Bdox's Avatar
Bdox
BINGO!!!!!!!!!
Old Mar 25, 2006 | 07:47 AM
Stuckinmud's Avatar
Stuckinmud
Well i was just gonna take it to the shop but now after you all think it may be the carb secondaries i might go check it out and see if i can get going myself.
Old Mar 25, 2006 | 08:41 AM
Stuckinmud's Avatar
Stuckinmud
Well im gonna go be checking out the truck this afternoon, how can i tell if the secondaries are open? Also how would go about closing them?
Old Mar 25, 2006 | 09:46 AM
Neb86's Avatar
Neb86
Look at your carb from the driver's side. There will be a linkage setup that has a cable or two hooked to it. That is your 'primary' throttle. Directly behind that (toward the rear of the carb) may be another linkage that is tied to your primary. Rotate that linkage by hand toward the front (counter-clockwise).
If your carb has vacuum operated secondaries you may only see a shaft sticking out. Grasp that as well as you can and rotate it forward.
Let us know how you do.
Old Mar 25, 2006 | 10:48 AM
frdnut's Avatar
frdnut
Remove the air cleaner and look down into the carburetor.You should see 4 holes with "butterflies" that close them.Depending on what kind of carb you have there may be 2 sets of butterflies on the rear.If there is a set right up at the top of the carburetor stick your finger into them.They should move freely by themselves.There will be anther set underneath these ones at the same level as the front one's.They are linked to the front butterflies by a linkage and should open once the front is opened around half way or more....If the carb only has one set of butterflies on the rear make sure they move freely and shut on there own.
Old Mar 25, 2006 | 03:35 PM
Stuckinmud's Avatar
Stuckinmud
Was driving the truck to the shop and it magically fixed itself. So i had the shop check it out anyway, they cleaned the carb up and adjusted some stuff and fixed my vaccum lines. Also got the brakes done while it was there, my truck has never ran sooo good. Cost me $200 but i think it was well worth it and post due. Ive owned this truck for awhile and havent put any money into cept for gas and a few oil changes and a few other minor things.
Old Mar 25, 2006 | 05:20 PM
Neb86's Avatar
Neb86
Glad to hear it!
Old Mar 25, 2006 | 05:43 PM
pfogle's Avatar
pfogle
$200 is cheap. I'd go thank that mechanic for being honest. Most would have charged you ~$800. Glad to hear you got 'er fixed.
F_TOUR
1978 - 1996 Big Bronco
Jul 3, 2019 10:20 AM
march
Jun 3, 2013 10:29 PM
hungwell
Feb 1, 2009 08:40 PM
1989BIG6
Oct 15, 2007 03:48 PM
