Electronic speedos?
Old Dec 27, 2002 | 09:44 PM
big block power's Avatar
big block power
Electronic speedos?
I was wondering if there is an aftermarket speedo setup
that doesn't use a cable since my drive gear is wrecked and
I'm not fixing it. I've heard about attaching magnets to driveshaft
then using sensors to detect revolutions.
Has any one done this or any thing similiar?
info is appreciated,thanks
Fe power
There....Fixed by Admin.
Old Dec 27, 2002 | 10:04 PM
1968F250LWB's Avatar
1968F250LWB
Electronic speedos?
First off you have an hour to edit your post.
Second, what year and model truck.
Russell
1968 F250 LWB 300-6
FORD=First on Race Day
#88 Dale Jarrett-9th in 2002
#21 Elliott Sadler
#97 Kurt Busch-3rd in 2002
#28 Ricky Rudd-10th in 2002
Old Dec 27, 2002 | 10:24 PM
tredway's Avatar
tredway
Electronic speedos?
i have a 69 f100 with 460 , used a cyberdyne speedo tach combo, with electric sender on the tranny, works great. made a custom dash insert out of black walnut. little work but worth the effort
Old Dec 28, 2002 | 08:45 AM
CACWBY's Avatar
CACWBY
Electronic speedos?
Big Block Power - I have a VDO Elect. speedo. It has to have a sending unit, which looks like some type of cable, and it still needs a driven gear inside the trans. VDO also sells the sending unit.
Old Dec 28, 2002 | 01:11 PM
big block power
Electronic speedos?
it's a 1972 f250 ranger xlt HD special with a 390 4v thats
slowly destroying the np 435 and D60 rear. The drive gear is busted
because the out put shaft or bearings in that area allow the
shaft to clink around. I just wanna know how fast I'm goin until
I stick in the t-18.
thanks
Fe power
Old Dec 28, 2002 | 01:38 PM
big block power
Electronic speedos?
neilfromatl
Sep 7, 2010 07:01 AM
1950gmcelc
Feb 16, 2009 01:57 PM
getsch58
1983 - 2012 Ranger & B-Series
Nov 29, 2008 05:36 PM
