speedo?
Old Feb 13, 2009 | 07:37 PM
1950gmcelc's Avatar
1950gmcelc
speedo?
Can i use a speedo out of a gas truck? My speedo bounces all the time and i have already changed the sensor in the rearend. So now im wondering if i can just change the speedo and maybe fix the problem. I found a used speedo out of a 96 f-150 on ebay for $12. Any help would be appreciated.
Old Feb 13, 2009 | 09:36 PM
tjbeggs's Avatar
tjbeggs
Yes you can use the speedo as long as you put that into your instrument cluster.
Old Feb 13, 2009 | 11:32 PM
bmxstreet15's Avatar
bmxstreet15
What Causes the speedo to bounce? I replaced my sensor as well. It didnt change though.
Old Feb 14, 2009 | 09:54 AM
tjbeggs's Avatar
tjbeggs
The PSOM goes bad. Its the "brain" of the speedo and ODO
Old Feb 14, 2009 | 11:30 AM
nelstone74's Avatar
nelstone74
Does the psom just fail or is there a usual suspect first like a bad ground or something along those lines.
Old Feb 14, 2009 | 12:08 PM
tjbeggs's Avatar
tjbeggs
No they usually just go bad. They can be repaired if you sent them here
Electronic Speedometer Service
Old Feb 14, 2009 | 06:28 PM
BlueMule's Avatar
BlueMule
FYI
When you swap out the speedometer module you'll loose track of the mileage that was on your truck and the odometer will now display the miles from the donor truck. Ya might wanna write down your mileage before you disconnect the old one.
Old Feb 15, 2009 | 01:41 PM
bmxstreet15
Oh cool! will my truck still run with out a speedo assembly?
Old Feb 15, 2009 | 01:48 PM
tjbeggs's Avatar
tjbeggs
If you have a manual trans are you are fine but if you have an auto it will incorrectly.
Old Feb 16, 2009 | 01:57 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Originally Posted by BlueMule
FYI
Yes thats right, and you can reprogram your speedo in the place that TJ linked, to match your mileage (I think I have read that is for law to do that).
blk450er
Sep 13, 2016 06:39 PM
Diesel_Brad
27
Nov 3, 2013 09:32 AM
hwm3
Jul 29, 2010 03:45 PM
Yogis1097
Jul 7, 2006 01:50 PM
xxl suv
Feb 28, 2001 04:13 PM
