351w heads
Old Mar 24, 2006 | 08:44 PM
uncle junk's Avatar
uncle junk
Smile 351w heads
im rebuilding my 351w and i was wondering how you tell if its a ho or regular heads ? what are the best stock heads i can run e7te s or should i use something elese id like to stay with cast heads the truck plows snow soo i dont want to go to crazy just would like to build up the motor a little bit i was told that a 351w ho from a mustang would have different heads than a 351w ho that was in a truck is this true the truck is a1986 carb job if that makes any difference . thanks for the help uncle junk.
Old Mar 24, 2006 | 10:10 PM
baddad457's Avatar
baddad457
E7TE's will work fine for what you want to do. Even better with the exhaust sides ported. Remove the injector bumps, raise the roofs and hog out the sides some, then blend them down into the bowls under the valves. Leave the port floor as is. Intake sides, just gasket match em. If you can, pick a machine shop that has a Serdi machine to do the valve job after porting.----------------------------------------------------The only 351 Stang heads that are better are the 69-70 castings. In the Fox Stangs, only one year offered a 351 and that was the Cobra R model. These had GT40 heads, which are somewhat similar to the older 69-70 castings.
Old Mar 24, 2006 | 11:45 PM
uncle junk's Avatar
uncle junk
whatwould the numbers be on a 69 -70 head i would like to go with the best were the e7te only on foolinfested motors or were the found on carb motors too
Old Mar 24, 2006 | 11:51 PM
miichael's Avatar
miichael
you looking for the 351W 4 barrel head casting numbers?
Old Mar 24, 2006 | 11:59 PM
uncle junk's Avatar
uncle junk
yes for a 69 -70 351w
Old Mar 25, 2006 | 12:01 AM
miichael's Avatar
miichael
im thinking the 4 barrel 351W was only in 1969 but i may be mistaking. I will look it up and see what i can find out for you.
Old Mar 25, 2006 | 12:05 AM
uncle junk's Avatar
uncle junk
i was wondering would the heads on a 1974 351w from a ltd crown vic be the same as th 69 -70 i have a chance to get them if i take away the mess that the poor car is in a shambles but its a free bee
Old Mar 25, 2006 | 12:08 AM
uncle junk's Avatar
uncle junk
thanks alot i really would like to finish this old girl she had an un expected motor death
miichael's Avatar
miichael
no you was right 1969 and 1970 heads offered a 4 barrel.
1969 351 V-8 Windsor 4 barrel heads -- C90E-6090-A, B, D, F, or J
1970 351 V-8 Windsor 2 and 4 barrel heads -- D00E-6090-C or D0AE-6090-J
Old Mar 25, 2006 | 12:11 AM
uncle junk's Avatar
uncle junk
hey miichale are you near killdevils hills nc. planing to take a trip there to go to the grave digger dungeon was wondering if you have been there would like to know if it is worth the trip from massachusetts
Old Mar 25, 2006 | 12:13 AM
uncle junk's Avatar
uncle junk
so wich head was the one i want any one of those numbers ???????
Old Mar 25, 2006 | 12:15 AM
miichael's Avatar
miichael
nope never been there so couldn't tell ya. im in the hickory area.
Old Mar 25, 2006 | 12:16 AM
miichael's Avatar
miichael
no you would want
1969 C90E-6090-A, B, D, F, or J
or
1970 D0AE-6090-J
Old Mar 25, 2006 | 12:19 AM
uncle junk's Avatar
uncle junk
well then ill let you know how it was over there when i go in june
Old Mar 25, 2006 | 12:21 AM
uncle junk's Avatar
uncle junk
thanks for the help im going to look for a set of 70 model heads
