Starter won't engage flywheel?
Old Mar 24, 2006 | 08:12 PM
firezone42's Avatar
firezone42
Unhappy Starter won't engage flywheel?
Hey all.
The problem is this: When I turn the key, the starter whines, exactly like it isn't engaging the flywheel. I am going on a date with my GF tonight and this is quite dissapointing, lol. I need some ideas, quickly please if you can.
The truck is a 1971 F250 Camper Special, restored.
Engine is a V8 Built 390.
That is all I know really, I am only 17 and this was a gift from my father.
Thanks everyone, I appreciate it.
-Nate
Old Mar 24, 2006 | 08:38 PM
daves54's Avatar
daves54
if the starter is not engaging some times a wack with the handle of a screw driver or lightly with a hammer will get it unstuck. if not your sol on the date!
Old Mar 24, 2006 | 08:39 PM
Hypoid's Avatar
Hypoid
The starter may be loose, but it's more likely a bad starter drive. If you have a spare starter, crawl down and have a look. Unit replacement is the quick fix.
Good luck, Mike
Old Mar 24, 2006 | 08:50 PM
amish77's Avatar
amish77
yeah, unless you have a clutch, then you could roll start it
Old Mar 24, 2006 | 09:24 PM
bertha66's Avatar
bertha66
Sounds like the starter drive, I'd replace the starter, if the drive is bad the motor may not be long for this world and if you got it off the whole thing out, you should replace it.
Old Apr 3, 2006 | 09:32 PM
bigdan1979f-250's Avatar
bigdan1979f-250
It sounds like a bad starter, however there is the remote possibility that it needs to be shimmed out.???
Old Apr 4, 2006 | 11:21 AM
amish77's Avatar
amish77
nah if it's spinning then the starter motor is fine, if it won't turn over it may be a bad starter. The bendix is the part that allows the starter to engage and disengage. This is the more likely suspect, and although you can kill two birds with one stone and replace the whole thing, its cheaper to just replace the bendix. I harldy think it matters to the poster any more though.
Grape Nehi
Jan 6, 2017 08:04 PM
Bartman1959
Jul 31, 2016 08:07 AM
mrk28645
13
Jun 24, 2014 05:48 AM
jgdrcr
Jun 18, 2014 02:05 PM
mr.fordneck
May 4, 2011 08:26 PM
