head gasket change and now wont start help
Old 03-24-2006, 03:23 PM
dekan513's Avatar
dekan513
dekan513 is offline
i done a head gasket change last night and well when i put it all back together and cranked the engine it just cranked over and over and never even tried to start if ne one has a sugguestion on what it may be please help
also if this is out of time how is the easiest way to check it and see if it is right or not
thank you
Old 03-24-2006, 11:24 PM
FortyFords's Avatar
FortyFords
FortyFords is offline
Well when looking at the front of the engine.
When the crankshaft mark is at 6:00 clock (keyway)
the right hand camshaft mark (driverside) is at 1:00
the left hand cam shaft ,mark is at 11:00
this what I remember .I will have to go look at my shop manua.
Rich
Old 03-26-2006, 08:21 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is online now
Did you put the crank sensor tone ring back on before you installed the timing cover? And I have always put the crank keyway at 12 o'clock whick puts the crank timing mark at about 7 o'clock and both cams are set to 12 o'clock then mark the chains and put them on lining up the marks. Never failed me yet.
jbg machine
1997 - 2003 F150
09-15-2014 10:55 PM
Johnsdeere
11-05-2012 10:24 PM
tjustice
07-15-2012 05:37 AM
dwayne21
20
05-15-2010 01:51 PM
caspian65
1997 - 2003 F150
08-01-2003 08:50 AM
Quick Reply: head gasket change and now wont start help
