It's me again
Old Mar 23, 2006 | 07:58 PM
toolebox1's Avatar
toolebox1
Unhappy It's me again
Here I go again,
The tow truck is having a problem Why does the distributor need 5 psi of vacume constantly? I can move the distributer advance or retard aslong as the vacume is on constant! HELP !!!!
Old Mar 23, 2006 | 08:35 PM
Homespun91's Avatar
Homespun91
A little more info needed.
I see by your gallery that the truck is a '60 (very cool, by the way, I like it!)- but is the engine original, & do you know anything about the distributor? What is it, or what year did it come from? And, what are you trying to do? Set the timing? Is this at idle?
I'm wondering if you have a LoadOMatic distributor. Alternatively, if it's the '57-up style, is the centrifugal advance working OK?
Old Mar 23, 2006 | 08:42 PM
CowboyPenner's Avatar
CowboyPenner
I love that tow truck!!!!
Old Mar 23, 2006 | 08:59 PM
toolebox1's Avatar
toolebox1
It Is The Original 292 With A New Bottom End Ie; Crank Bearings Ect...
Anyway The Dist Is The Old Style With The Weights.
What Happens Is When I Try To Start The Darn Thing It Wont Start Unless I Use A Vacum Pump And Set It At 5 Or More Psi. It Just Started Doing This 2 Days Ago And I Cant Figure What Is Wrong Or Why It Is Doing It.
Old Mar 24, 2006 | 08:39 PM
Homespun91's Avatar
Homespun91
Well, a couple of things come to mind. You are basically adding some advance to the timing, or that's what it sounds like. This makes me think that the initial timing is way off. I'm assuming from what you've said that it has been running fine for a while, until just two days ago.
If you haven't done anything to the dizzy to cause this, & it wasn't loose, and/or it wasn't removed & replaced, then I'd have to wonder if the advance mechs. are broken, or if the timing chain has jumped a tooth (presuming the timing set was installed right, you remember the marks don't line up when installing a timing set on a Y), or the gear pin has partially sheared; something to move the initial timing.
Again, I am assuming that it was fine until just a few days ago. (Therefore the timing set was probably put in properly.) I'm also assuming you've covered all the basics- fuel, air, spark, spark at the right time. Plug wires weren't removed or anything, right?
If you can't get it fixed (& it easily could be something simple that I've overlooked/not mentioned), then I would probably first try rotating the plug wires on the cap one position advanced & see if that makes a difference; then, I would pull the distributor, check it over, including both advance mechanisms, bring the engine to TDC, & reinstall it from scratch.
Hope this helps a little. Not trying to knock your mechanical skills, just going through the basics.
Old Mar 25, 2006 | 06:48 AM
toolebox1's Avatar
toolebox1
That is correct nothing was moved or adjusted when the problem started. Like I said it was running fine until a few days ago.
Right no I have the distributor full foward and 5 psi vacume advance and it starts good and runs well. It maybe a bad distributor.... You think?
Old Mar 25, 2006 | 04:58 PM
Homespun91's Avatar
Homespun91
"It maybe a bad distributor.... You think?"
It's possible, but I think it's less likely. Normally, at idle, you would have the initial advance, plus, possibly a little centrifugal & vacuum advance, depending. From what you are saying, it sounds as if you are having to put in as much initial advance as possible (as far as you can turn the dizzy body), PLUS apply some vacuum advance, just to make it run. This makes me think that the rotor is WAY off (retarded) from where it should be at TDC. Typically, this is caused either by improper installation (aka "a tooth off"), or the timing chain jumping a tooth, which almost always retards the cam & ignition. Since the dizzy wasn't taken out...
That's why I suggested this:
"If you can't get it fixed (& it easily could be something simple that I've overlooked/not mentioned), then I would probably first try rotating the plug wires on the cap one position advanced & see if that makes a difference; then, I would pull the distributor, check it over, including both advance mechanisms, bring the engine to TDC, & reinstall it from scratch."
If you move the wires over one cap post, you might/might not need to back off the dizzy from its full advance position to make it run again.
Again, I could be way off- this is just what I'm seeing from here. At least these two areas are fairly easy, & free, to check.
If the distributor does prove to be bad, & unfixable, Advance Auto, NAPA, AutoZone, etc. all can get the current Cardone-rebuilt dizzy within a few days. OTOH, if moving the wires or the dizzy seems to help, & nothing is wrong with the dizzy or its centrifugal advance, I would seriously suspect the timing chain (or broken gear pin/gear)- & if it's jumped once it'll do it again sometime.....
P.S.- also assuming point gap & dwell are reasonably close to where they should be...
Old Apr 22, 2006 | 06:18 PM
toolebox1's Avatar
toolebox1
It's fixed !!!!
Well this is what I did, I put on a new distributor with petronix ignition and now what a difference.
Thanks for all your help!!!!!
Old Apr 23, 2006 | 04:49 PM
captradiator's Avatar
captradiator
Toole,
That is a nice-looking wrecker you got there. However, it appears to be larger than an F-350, perhaps an F-500? I ask this because of the five-lug wheels, since my '56 F-350 has the six-lug wheels...
Johnny
Old Apr 23, 2006 | 07:12 PM
toolebox1's Avatar
toolebox1
No it is just a 1 ton. someone just changed up some stuff.
loquito
May 9, 2014 09:01 AM
EMC V10 X
Jan 10, 2011 11:11 AM
mtcrss14
Oct 6, 2007 10:51 AM
ewellman
Sep 30, 2003 12:01 PM
kman2785
Dec 13, 2002 12:44 AM
