352 running rich?
Old Mar 23, 2006 | 02:07 PM
trvaughn's Avatar
trvaughn
352 running rich?
What are some ways to tell if the engine is runnign rich? I'm a little over 900Ft. higher in altitude than where I bought the truck, and last week I walked behind my truck to get some water for the windshield and when I looked down my pants were coverd in little black specks. I'm guessing its running rich but I'm not that familar with this type of thing.
THis is a 66 F-250 with a 352.
Thanks much,
Travis
1958 Mercury Monterey 4dr sedan 383 V8
1966 F-250 Camper Special/Custom Cab 352 V8
1997 Explorer 4dr AWD XLT 302 V8
Old Mar 23, 2006 | 02:58 PM
rusty70f100's Avatar
rusty70f100
Pull a few plugs and check the color. The grounding strap tip should be light tan to almost white colored. Darker means rich. Black with deposits means burning oil, all white with little spots means lean. Cracked insulators and white with little spots means really lean to the point of pinging. Greenish means antifreeze. You can tell a lot by looking at spark plugs.
It's not uncommon for water to condense in the exhaust and carry some carbon with it. Still check the plugs.
Be sure to check back with the results, I get curious about how this kind of thing turns out!
Old Mar 23, 2006 | 03:00 PM
Redmanbob's Avatar
Redmanbob
The specs are probably just condensation in the pipe thats getting blown out upon startup/warmup.. Does it do that after it's been driven for a good while ? I live rather close to the beach and every day the marine layer causes this unless your auto is garaged/
Old Mar 23, 2006 | 03:04 PM
trvaughn's Avatar
trvaughn
K i'll give the plugs a check this weekend. I havn't check to see if the speks still appear after its been running for a while. I'll have to check it when I go home from work today and check it again when I get home.
Thanks for the info!
Travis
1958 Mercury Monterey 4dr Sedan 383 V8
1966 F-250 Camper Special/CUstom Cab 352 V8
1997 Exploter 4dr AWD XLT 302 V8
robbv
22
Feb 16, 2017 07:29 PM
blaster4d
Dec 26, 2014 03:02 AM
Thebandit328
Nov 28, 2014 03:23 PM
duke_boy
23
Jun 26, 2011 02:04 AM
rusbukt
Feb 10, 2008 08:28 PM
