time for a tune up
Old Mar 23, 2006 | 09:52 AM
bigblack02's Avatar
bigblack02
time for a tune up
i just turned 45,000 miles on 2002 5.4 and i want to do a tune up.
my questions:
what type of plugs should i go with, same as stock?
should i change the fuel filter?
change the coolant?
anything else i should do since i hit 45,000?
thanks for your help
Old Mar 23, 2006 | 11:09 AM
sw99's Avatar
sw99
Plugs... Depends. They are supposed to be good for 100K. I did all of mine at 60K just for grins and a irratating COP issue. Fuel filter, yes... They are cheap and very simple to replace. It sure would not hurt to have the coolant flushed and filled with new coolant either. Obviously, you'll want to check the air filter as well and perhaps check the tranny fluid and or replace.
Old Mar 23, 2006 | 11:37 AM
Ron McCafferty's Avatar
Ron McCafferty
Exclamation time for tune-up
Motorcraft plugs are probably best, but Autolite makes a good platinum plug. Just be careful when torquing the plugs. I just had a plug get blown out the head after I changed the plug 40K miles ago. The original plugs should be good for 100K.
Twanstyle
Sep 16, 2014 09:13 PM
Peterooster
2004 - 2008 F150
Jun 12, 2012 07:56 PM
06F150Guy
2004 - 2008 F150
21
Jul 19, 2009 02:27 PM
ptr34
Apr 24, 2009 06:10 AM
WHITESTANG95
1997 - 2003 F150
15
Jun 9, 2005 08:44 AM
