Squealing left front Hub
Old Mar 22, 2006 | 03:10 PM
dcara's Avatar
dcara
Yesterday I was coming back up from the back pasture on a white rock road at about 10mph when my left front hub started squealing. Sounded like metal on metal. I checked to make sure I hadn't picked up any bailing wire or rocks. None that I could see. I have a 99' F250 4x4 with 98k miles. I had put into 4x4 earlier when I was down in the pasture and then unlocked it when I came out of the pasture. About 4 months back the 2/4 wheel drive shift on the fly went out so I've been using manual lock instead. None-the-less, I always put the switch in the matching position to what I have the hubs in. Thought, I would get the left front off the ground in the next couple of days and see if I could turn it by hand with and without the hubs locked. Not sure what to do after that though. Any suggestions appreciated.
Doug
Old Mar 22, 2006 | 04:36 PM
kawika's Avatar
kawika
Did you pick up a rock betweeen the rotor and caliper/pad? I picked one up and until it fell out, it squeeled.
Old Mar 22, 2006 | 05:48 PM
Ed Willmott's Avatar
Ed Willmott
My squeal turned into a new hub assembly - $280 plus an afternoon.
Old Mar 22, 2006 | 06:01 PM
SpringerPop's Avatar
SpringerPop
Did a hub today.
Pop
Old Mar 22, 2006 | 06:19 PM
clux's Avatar
clux
I've had the same experience on several occasions. The right sized rock on top of the caliper can can get right up against the rotor.
Old Mar 23, 2006 | 09:32 AM
dcara's Avatar
dcara
A rock must have been the problem. I got the left front off the grounf this morning and turned it by hand. At first I could hear the squeal, and then I heard something rolling/clunking around in there, and then all noises stopped. But I never saw anything drop out of the drum. I drove it around for about 10 minitues with and without the hubs locked and didn't hear any more noises. Things seem okay now. What are the chances that whatever it was is still in there and creating a future problem?
Old Mar 23, 2006 | 09:44 AM
mtgrzlyman's Avatar
mtgrzlyman
i had the same thing happen last summer the noise quit and havent heard it since. mine went on for about a week though??? also i had if 4x4 for a short distance this winter and when i diengaged 4x4 noise was ther for about 40 miles then no more??
Old Mar 24, 2006 | 07:54 AM
BlueOvalBoy's Avatar
BlueOvalBoy
$289 here, "Discovered" it during bj replacement. Damn rotor layed right over on the brake pad bracket.. Never seen that before hope not to see it again. Probably drove it 1500 to 2000 miles that way. My bad and my luck it didn't disintegrate on me. Integral bearings
Peace
Old Mar 24, 2006 | 09:41 AM
RobertJohn's Avatar
RobertJohn
I had the rock issue as well, thought I'd really torn something up.
Another problem can be those little spring clips that hold the pads off the rotors.
I'm going to do a hub later and will probably get new clips since they rust etc..
How are u guys installing the new seal on the axle ?? DYI or having someone else do it ?
Citizenrain
Mar 12, 2012 02:33 PM
keyul
May 24, 2010 07:50 PM
bodabdan
52
May 6, 2005 03:53 PM
westtexasbaja
Apr 3, 2005 01:02 PM
fairlaniac
Dec 28, 2000 11:42 PM
