FORDD F-100 DISC CONV. PROBLEM
Old Jan 5, 2003 | 11:48 PM
eleanor67's Avatar
eleanor67
HEY I REALLY NEED SOME HELP IM IN BIT OF A BIND RIGHT NOW I WAS WONDERING IF ANYONE OUT THERE CAN HELP ME WITH MY PROBLEM.
I HAVE A 1970 FORD F-100 AND I RECENTLY CONVERTED IT TO DISC BRAKES USING PARTS FROM A DONOR 1979 FORD 1/2 TON I SWAPPED OUT THE I-BEAMS, RADIUS ARMS, AND AFETR I HAD IT ALL IN AND BOLTED UP I FOUND THAT THE BRAKE LINES WERE TOO SHORT THEY WILL SNAP UNDER A HARD TURN I WAS ONDEWRING IF ANYONE KNOWS IF THERE IS ANOTHER BRAKE LINE FOR A LATER YEAR TRUCK OR SOMETHING ELSE IT NEEDS TO BE ABOUT 3-4 IN. LONGER BY THE WAY IT HAS THE LINES THAT HAVE THE SQUARE END WITH THE HOLE IN THE CENTER.
ANY HELP WOULD BE GREATLY APPRECIATED
THANKS
Old Jan 6, 2003 | 01:22 AM
rebocardo's Avatar
rebocardo
Take the hoses to NAPA, that you have, have them match it end to end with one from their hydraulic catalog and then just order one four inches longer. I think on your year they used 3/8 male fitttings on both ends?
That is how I got new hoses for my F-100 when there were none listed in any catalog.
Old Jan 6, 2003 | 01:25 AM
eleanor67's Avatar
eleanor67
THANKS DUDE FOR ALL YOUR HELP MAN I'LL TRY THAT AND SEE WHAT HAPPENS
Old Jan 6, 2003 | 08:38 AM
evans's Avatar
evans
Move the mounts for the brake lines forward.
Mike
Old Jan 6, 2003 | 06:49 PM
jowilker's Avatar
jowilker
Eleanor, typing with the caps on is considered shouting, so STOP IT. You need the donor hoses or like new ones, and run them like the donor truck. That should solve your problem.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member 0004 since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Jan 6, 2003 | 11:26 PM
oughtsix's Avatar
oughtsix
I concur. I used the donor trucks hard lines and mounts. I drilled a couple new holes to mount them.
Old Jan 7, 2003 | 02:32 AM
zsir's Avatar
zsir
Consider looking into a set for a 4x4......They should use the same bolt style and might be longer.....
worth a try..
Old Jan 7, 2003 | 10:52 AM
William's Avatar
William
Baer
May 18, 2016 08:06 AM
johnmel59
Dec 11, 2014 02:55 AM
jerryst
Oct 5, 2011 10:29 PM
PASTORMATTHEW
Nov 9, 2006 10:42 AM
Nitrobasher
Aug 23, 2005 01:15 PM
