Sponsored by: Innova
Subwoofer box
Old Mar 21, 2006 | 06:10 PM
Fordbyford's Avatar
Fordbyford
Exclamation Subwoofer box
I have bought my audiobahn setup(Subs and Amp) I just need a box now I have all the Box sprcifications printed up I need a box that has 1.3 cubic feet worth of air space,but anyway was woundering if anyone out there would recomened a box for my spcs I have all the info right here, I wanted to make a vented box if your any good at building boxes maybe you can help me out with tis I would like to build the box myself (cheaper) I have 2 8'x 3' 3/4 MDF particle board sitting in my garage please help me out here~Kyle
Old Mar 21, 2006 | 07:08 PM
fordboy_52's Avatar
fordboy_52
i think i do have the same subs as you have as u said in that pm. i have a huge box with full air flow. its amazingly big and i dont have any specs on it. i recommend a box much like it as the subs sound AWSOME
Matt
Old Mar 21, 2006 | 07:14 PM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
What kind of truck do you have? Year? Standard cab, or extended? I have plans for a box in my gallery for a dual sub setup. You could easily adjust it and add more volume to the boxes. You can usually make the boxes slightly smaller if you seal them off. 12" subs only need 1 cubic foot of volume in a sealed box.
Ryan
Old Mar 21, 2006 | 07:31 PM
Fordbyford's Avatar
Fordbyford
I have a 96 Ford bronco XLT. I have 2 12" Audiobahn AW1251T's I got the specs on the boxs they have and a space saver box only needs 1.3 Cubic feet of air space as an everyday bass performer needs 2.3, An Ultimate SPL Bass box needs 3.15 and a sealed box only needs 1 cubic foot of air space
Old Mar 21, 2006 | 07:46 PM
Fordbyford's Avatar
Fordbyford
See the thing I want todo is creat a ported box I have all the necissary tools and equipment for this I just need to know how to measure the cubic feet in the box now from what I understand is you multiply HxWxL and divide it by 1728and that will give you your awnser is this correct?
Old Mar 21, 2006 | 09:00 PM
FghtinIrshNvrDie
yeah. There is 1728 cubic inches in a cubic foot. LxWxH. Easy math equation for almost anyone.
Ryan
Old Mar 21, 2006 | 09:22 PM
RangerPilot's Avatar
RangerPilot
For a perfect square or rectangle. If it's inclined any way, that formula won't work.
Old Mar 21, 2006 | 09:41 PM
FghtinIrshNvrDie
right, but What you do is pretend the triangle part is squared off, then measure it as such. Then, measure the part of it that's slanted, preted like it's still squared off, and divide by 2. Did that make any sense? It's hard to explain w/out visuals.
Ryan
Old Mar 22, 2006 | 06:44 PM
Fordbyford's Avatar
Fordbyford
So wait this is what I figured with your last post Ryan you LxWxH divide by 1728 then divide by 2? if that is correct I have this formula 16x16x16=4096 Divde 4096 by 1728 gives me2.37037037 then divde that by 2 and I will get 1.18518519 Is this correct? If so screw it I'll just make a sealed box. I was going to make a ported box but my calculations were off by a hair I had 16x16x17 divided but 1728 and that gave me 2.51857852. the problem with that is how I would fit the 17 into the 16's. Does this make sense probally not If your having trouble understanding this I'll explain it better if you ask~kyle
Old Mar 22, 2006 | 06:47 PM
Fordbyford's Avatar
Fordbyford
One last thing if I make a sealed box would it be better if the box was bigger or smaller?
Old Mar 22, 2006 | 07:50 PM
fordboy_52's Avatar
fordboy_52
sealed doesnt matter bigger or smaller, make the box to the specs
Matt
Old Mar 22, 2006 | 08:01 PM
RangerPilot
Yeah. Bigger or smaller doesn't matter. As long as the interior airspace is the same, it's going to, for normal purposes, sound the same. Especially with a sealed box. Here, see if this helps.
http://www.diysubwoofers.org/
Old Mar 22, 2006 | 10:55 PM
furball69's Avatar
furball69
No, that is not correct; he was talking about a box that is angled. So, the bottom of that side is 10" and the top of the same piece is 6", you don't have a rectangle but fot the purpose of simplifying the math, you add those two measurements and divide by two, giving -- 10 + 6 = 16 / 2 = 8.
if your other two sides were 16 & 16, the math would be 16x16x8/1728=1.185
It's also a good idea to make the dimensions uneven, like add a third to each side starting with the depth of say 8 or 9 inches, width of 13 - 14, height of 16 - 17, something like that. having all sides equal can make the box resonate and sound bad. I generally start with the face plate (front), top, bottom, and back, then drop the two sides in.
Almost forgot the links
http://www.crutchfieldadvisor.com/IS...build_box.html
http://www.lalena.com/audio/faq/build/
Old Mar 23, 2006 | 03:02 PM
Fordbyford's Avatar
Fordbyford
I know this is jumping off the subject but my battery died lastnight and I would like to test my systems power how do I go about testing the cable that runs from my battery to my cap into the amp?
Old Mar 23, 2006 | 03:08 PM
FghtinIrshNvrDie
test the cable..? For what purpose? You make sure you have a solid connection to your power supply, check the fuse, and check for a solid connection to the amp.
Ryan
